McIntosh MI254 Power Amplifier Teardown
Greetings, fellow ASR readers.
Long time lurker, first time poster here.
This is a quick teardown of a McIntosh MI254 4-channel power amplifier. This amp is used as a supplement to the Marantz SR6014 AVR for home theater duty. It is powering two front channels and two surround channels.
I have been a McIntosh fan ever since I saw the C712 + MC7150 set up at my uncle's place back when I was a kid. It was purchased new since the mid-90's and has been a flawless performer for over two decades. However, even though the amp is slimmer than other McIntosh models, the MC7150 itself weighs in at a hefty 26 kg (58 lbs). I assume that the majority of the weight comes from the autoformers.
Fast forward to 2019, I bought the MI254 new from a local authorized distributor. AFAIK, this is among the very first Class D amp McIntosh has ever produced, a departure from their traditional Class AB and tube designs. Aside from the MI254, McIntosh also have a MI128, an 8-channel amplifier specifically for whole home audio distribution, and most recently, a MI347 7-channel home theater amp, both of which are also Class D. Only the MI254 comes with the blue meters though.
The amp is slightly thinner than the MC7150 but weighs in at around 10 kg (23 lbs) which makes it very convenient to move around and set up. There's also an option for a professional rack mount as well.
The backside has a multitude of connections, including unbalanced RCAs and balanced XLRs, or you can switch over to Bus 1 or Bus 2 and use the amp for bi-amping or different pair of speakers. By using Bus 1 and/or Bus 2, it is possible to daisy-chain to other amplifiers for other room / zones.
Serial number blocked, for obvious reasons.
Top cover on.
Removing six screws (2 in the front, 2 in the center, and 2 at the back) and top cover comes off.
The amplification duty is handled by four Hypex NC500 OEM modules. The fact that it is powered by Hypex, along with great reviews, combined with the blue power meters made it an instant buy for me.
The NC500 module is fitted with Samwha capacitors, similar to many other NC500 implementations. There are separate heatsinks for each module.
The amp itself appears to be using a custom switching power supply as opposed to Hypex's own. It is multi-voltage though.
There appears to be a mix bag of Japanese, Korean and Chinese capacitors. I have very limited knowledge on electrical designs so I can't really comment on its duty.
Jianghai CD297 capacitors, rated at 105C.
Here's are Nichicons. I've heard rave reviews from PC power supplies using these caps so I guess they are top notch.
And here it is, with blue lights on in the theater room.
I do apologize for questionable photo quality though. There appear to be a size cap so some photos were resized.
Billy Budapest
Is this the McIntosh amp that supposedly has SOTA measurements?
W
Billy Budapest
W
Any reactions on the sound ?
This is going to be a tough one to describe. I would recommend an in-store demo if you could.
Before I bought it back then, the local dealer had the MI254 matched with the Sonus Faber Olympica Nova. It sounded epic, but those speakers were way beyond my budget range.
Vacceo
It would be amazing if you were kind enough to allow Amir to put the amplifier on the test bench. It is an Ncore based product, so it should be pretty good, but other companies (NAD with Purifi) have managed to provide worse results than baseline amps, so...
From this amp, we could also get an idea about the 7 channel MI347, which I think is basically the same thing in its higher power 3 main channels.
MakeMineVinyl
Santa Fe, NM
Umm....... NC500 modules. Where have I seen those before? Is that a PIC16F690 on the modules with an ICSP port next to it? Nah, must be seeing things. :oops:
Vacceo
Another question in regards to heat: will it need fans when rack-mounted with other components?
MakeMineVinyl
Santa Fe, NM
Class D usually doesn't generate enough heat to need a fan.
sarumbear
Top cover on.
You can say many things against the brand but production quality is not one of them. Their equipment are always immaculately manufactured.
restorer-john
You know what's in an NC-400OEM ;)
Vacceo
That is the point: in general. Beyond the Hypex modules there is a power source and other electronics, and those could be not as efficient as the NC500. Hence the question if they can be stacked on top of each other on a rack (something that McIntosh does not recommend).
CinDyment
Familiar with a wide variety of off-shore capacitors. Some good, some bad. What worries me is I have never seen printing that poor on a real Nichicon capacitor:
MakeMineVinyl
Santa Fe, NM
Even linear power supplies don't get all that hot. The real heat dissipation, at least in a class A/B or class A amplifier is in the output stage transistors. Switching power supplies are very efficient and don't generate all that much heat, at least not to the point which would likely need a fan.
Beyond all that, if you are finding that you are stacking your components so densely that heat is a concern, you're doing something terribly wrong. You need to physically space out the components and arrange them so heat doesn't build up.
restorer-john
Familiar with a wide variety of off-shore capacitors. Some good, some bad. What worries me is I have never seen printing that poor on a real Nichicon capacitor: View attachment 194083
If you look hard at the picture, that capacitor likely has a dent in the can and that is making the sleeve print look as poor as it does. (the same effect is seen over the base-crimp on the same cap) Combined with low lighting and low resolution, the cap looks like a dodgy fake. I don't think it is.
Chrispy
PNW
So your company doesn't use fans particularly in your designs? Anything special in heat sinking for the output stage? What would you say would be any advantage/disadvantage to McIntosh's autoformers vs your own executions?
MakeMineVinyl
Santa Fe, NM
Some of our amplifiers, and the professional amplifiers in particular, use fans which are thermally controlled. Most of our amps don't use fans. We are known for large heatsinks and beefy construction.
Autotransformers vs conventional is really apples to oranges. No particular shortfalls in either approach.
Doodski
The outer sheath that you see is shrink wrap and it sometimes distorts when being shrunk/applied. No cause for worry. If it is really stretched and splitting then the capacitor is bursting open and needs replacing but in this case it's just distorted dimensions from the shrinking process.
