Measurement instrument for measurement novice
Phorize
U.K
I’m interested in taking sound measurements in my room, to help understand how my speakers are performing and placement etc.
is their such a thing as an entry level sound level meter or similar instrument for spl measurement etc?
PierreV
RayDunzl
Central Scrutinizer
Riverview FL
Blumlein 88
I'm just chiming in with the others. Umik 1, and a computer is all you need. Well and free excellent Room EQ Wizard or R.E.W software.
RayDunzl
Central Scrutinizer
Riverview FL
Included in REW...
To get the same SPL featues in a hand-help SPL meter would probably cost as much or more than the UMIK-1
phoenixdogfan
Nashville
Thanks to the PC, freeware like REW, and low cost calibrated USB mics like the Umik-1, we're in a golden age for this kind of thing. BTW, I'd also invest in a microphone stand--should run aroud $30 at Amazon.
Helicopter
Michigan
I am in the same boat except I already have a Focustite scarlet 2i2 audio interface. Would you still recommend a USB Umik, or would I be better off getting a calibrated XLR microphine to get started?
technoian
As you already have the audio interface I would agree that a calibrated microphone would be the way to go. I use a Sonarworks XREF20 but there are others with similar specs.
Sal1950
The Chicago Crusher
Central Fl
Once you folks get accustomed to the REW (free) software and learn how valuable it really is, don't forget to throw the long time developer John Mulcahy a tribute for all the hard work he puts into REW. ;)
