Measurement MacBook Pro Output (Newbie)
Hasan Aydin
Germany
hello,
I want to measure my MacBook Pro headphone output with my ADI-2 Pro using the REW software. This is the first time I measure something and I'm a beginner.
My question is:
Can I use a simple 3.5mm jack to XLR cable for this or would that be a problem because that is unbalanced to balanced connection?
Something like this: Screenshot 2022-06-05 at 13.09.35.png
AnalogSteph
.de
Note - do this with the Macbook on battery and the RME on another machine in order to eliminate ground loop issues. Yes, REW's author says
You can save REW's measurement sweep to a WAV file from the signal generator, including a timing reference if desired.
(If you need to record on a Windows machine, note that ASIO has to be used for >16 bit samples.)
If you do need a loopback measurement on the same machine, your best chance at a (largely) bulletproof measurement setup would be making your own cable or at least modifying an existing one if feasible (a lot of XLR connectors will open / unscrew but not all may). The most likely configuration to be found is
Signal --> XLR pin 2
Ground --> XLR pin 1, plus bridged to pin 3
What you'd want is
Ground --> XLR pin 3 only
