Measurements of FIIO X1 ii
Arnold Krueger
Technical Tests of FIIO X1 series ii Digital Audio Player
  • FIIO X1 I to Microtrack I 2496 04-06-2018.pdf
This is curious:
Why this narrower range than 20-20 kHz?
Arnold Krueger
Arnold Krueger
This is curious:
That is the author's choice. However it makes some sense because not only does audibility go down at the frequency extremes, but so does our sensitivity to variations.
The illustration shows this fairly well known psychoacoustic effect, The broader the frequency response error, and the closer it is to the midrange, the less the ear tolerates it,
The attachment shows how wide and at what frequency a response variation has to be to be in danger of being audible, using a fairly sensitive risk adverse standard.
The best recent AES paper relating to this is F. E. Toole, S. R. Olive: The Modification of Timbre by Resonances: Perception and Measurement, JAES, vol. 32, March, 1988, 122-142. Also online for everybody: DETECTION OF AUDIBLE RESONANCES Ivo Mateljan, Heinrich Weber*, Ante Doric** http://www.artalabs.hr/papers/im-aaaa2007.pdf
Well, the idea of measurements is that we get all the data and then apply psychoacoustics to it. If you don't have any response measured above 15 kHz, how do you determine if it is or isn't audible?
Also response below 40 Hz is useful to know if the device is DC coupled or capacitor.
On your enclosure which is from Clark's paper, there is important text that goes with that figure:
So while directionally that may be right, I don't think it provides justification for not measuring what is going on outside of 40-15kHz.
On Dr. Toole/Olive's paper, I have read that many times. Which specific portion do you think applies to this?
Arnold Krueger
Arnold Krueger
I agree, and so I also post a traditional frequency response curve covering a much wider range. I regret that the previous PDF file was missing some graphics, but that should be corrected now.
All of it and none of it, because IMO it is not stated in such a way as facilitates comparison with ordinary frequency response measurements.
I've been working on a way to restate its results in a way that is more useful for me.
Wombat
Australia
Bell Research in the past established a link between lower and upper frequency break-points wrt telephony clarity. As the lower frequency break-point decreased the upper break-point was increased (or vice-versa) to give a balanced spectrum for audio balance.
That 40-15kHz spectrum reminds me of that work.
Arnold Krueger
Arnold Krueger
My take is that while the 20-20 KHz range is easy enough to remember, it is more of an icon than a real world standard.
For example, most people who have downloaded and reported on using a CCIF 19+20 KHz file for listening, report that it is silent when they play it.
When CRT based TV sets had 15.75 KHz flyback transformers that spread sound at that frequency, very few but the youngest ever seemed to notice it.
A lot of perceptually coded files are found to be very satisfactory in critical blind tests and many of them are brick walled at 16 KHz.
Very few speaker systems reproduce 20 Hz audibly and cleanly, and life seems to go on for the vast majority of audiophiles without it.
FM stereo was low passed at around 15 KHz using passive analog filters that had wide transition bands and nobody seemed to complain.
Almost all common musical instruments have a note in their 32-45 Hz as their lowest ordinarily played note.
Since about 1978 an increasing percentage of LPs were cut with in-line low pass filters with relatively gently sloped and wide transition bands that intruded well below 18 KHz related to cutting lathe pitch automation, and nobody seemed to complain. In fact many seemed to say that they preferred LPs even though the vast majority cut up until about the mid-90s had this fault.
Conclusion - the 20 Hz - 20 KHz range is generally for almost all listeners overkill and far from being sacrosanct.
Sal1950
The Chicago Crusher
Central Fl
FIIO X1 ii
04-05-2918
Whoa, Arny must be time warping with Scotty on the Enterprise compiling this data. :eek:
Or is it STNG's Data compiling the data? :confused:
Wombat
Australia
Except for electronic and pipe organ music there are few recordings that exceed the 40-15kHz range. Only youngsters are likely to hear above 15kHz.
Arnold Krueger
Arnold Krueger
The best recent papers I've read suggest that wider range within the ordinary audio range yields better intelligibility if there are not strong interfering signals. Reducing bandwidth to attenuate irrlevant signals remains an effective strategy.
If we simply allow ourselves to believe most recent scientific papers, response beyond 20 KHz generally has little or no effect. In order to obtain more positive results than that requires heroics that most people and producers are not going to put forth. For example, most microphones and loudspeakers that are used in recording and playback have roll-offs, even on axis that are either within or just outside the 20-20 KHz range. Many so-called omnidirectional speakers and microphones never were all that flat off-axis.
For example please observe the directionality of a common high quality "omnidirectional" microphone that is used for recording and measurements (attached). Note that there is 20+ dB of attention @ 20 KHz off axis and the laws of physics suggest that it only gets worse as you go higher. Trust me, the cheaper ones are no better unless they are smaller and this one is pretty tiny!
Arnold Krueger
Arnold Krueger
I believe that this may be the most over-arching of all current audio standards - the standard for transmission of audio via satellites various named J17 and BS 644.1
I suspect that the vast majority of what you hear via broadcast may have passed through a device that barely meets these standards.
Damien Tougas
Montreal, QC
Is there someone who can interpret those measurements for me? I am new to reading the graphs, and don't have a feel yet for what is good or not-so-good...
Foxxy
Austria
I know this is really late but... I have the player and while it's an excellent source, depending on the headphone load distortion shoots up to really audible levels, ruining the sound. So buyer beware.
Speedskater
Cleveland, Ohio USA
For decades, even back in the old news-group days 'ArnyK' was the go-to source for info on sound-cards and A/BX testing. But his manner could be abrasive at times.
