Measurements of Gustard P26 Preamplifier
WolfX-700
China
More than a month ago, an old friend asked me, would you measure a Gustard P26 preamp?In fact, I didn't know Gustard was going to launch this product until he asked me.I then contacted Gustard, who said at the time that P26 had not been officially completed. After the official release, I will send me a retail version for measurement.
Just a few days ago @Max Also ask me if I will measure this unit?In fact P26 was on the road the next day.
Today I got the P26, and the measurement took me a lot of time. Because the preamplifier is very different from the DAC, there is basically no SOP at all. If there are any shortcomings in the following measurements, if you want to know something else, please let me know.
Look at things first:
Actually I always wanted a decent preamp
In fact, I always wanted a decent preamp, but the tragic fact is that it is almost full of garbage (maybe I didn't find it) under $ 1,000. It is not just a defect in the measurement data, but a question of completion.
What I mean by completeness refers to the appearance, function (input and output interface), operation friendliness, function implementation results (such as noise when switching volume), and even the ability to clearly show what you want What you know (input, output, volume, etc.)
This even forced me to do a preamp to achieve what I wanted.But although I realized most of what I wanted, it still couldn't satisfy me. Because the interior is composed of various small modules, and some modules are purchased (such as input and output switching and display), it cannot be said to be a "finished product" at all, but only a "usable" thing
And the cost of making it is close to $ 1,000 (not including the time I spent!!)
And Gustard's long-term adherence to the discrete voltage amplifier circuit has made me have a little more expectations for the sound of this preamp.
Well, don't talk nonsense. Measure it!
Update: Left channel PS Noise issue has been fixed and the manufacturer has been notified of the fix. Since repairs do not require costs, manufacturers will immediately produce to new standards. :
We can see that there seem to be two sets of very different input stages. One is responsible for the input of the balanced signal, and the other is responsible for the input of the unbalanced signal.
In fact, I also got this information from the developer, and the circuit of unbalanced input will also be used for "input gain + 6db setting". This means that the input gain +6 will also affect some basic measurement results in the same way as above.
Fortunately, we generally do not need a large input gain. And if you really feel that the sound is too low (this preamp is actually close to 0db gain by default) you can start "output gain +6" Settings ---- This function does not affect the basic measurement results.
The following measurements were made at XLRin XLROut 4VRMS:
First and foremost: volume control:
You can see that the volume control is very linear and the channel balance (green line) is very good. At the same time, the effect of volume adjustment on SINAD is minimal. The disadvantage is that the limit value of the volume control (-60db)may not be low enough in some cases.
Output impedance:
THD+N Vs Freq:
All of the above, I think for a preamp of less than $ 700, it is very, very, very good.
I've measured DACs from Gustard before, and to be honest, I'm a little disappointed-let's say the A22 finally achieved the result with double 4499.
I also said that Gustard's insistence on discrete output stages may be the main reason that affects the measurement results of their products.
But on this product today, I really have nothing to say.
A low-cost, high-performance, good-looking preamp. Sorry I have never met before.
What's past is prologue. The future can be expected.
Xulonn
Boquete, Chiriqui, Panama
$699 on eBay, free shipping from Hong Kong to USA. Unfortunately, I don't need a preamp any more with only digital sources.
rodtor
Toronto
This is a good point. Are there other reasons for using a preamp now if one has a good DAC-power amp combination, with compatible voltage levels?
WolfX-700
WolfX-700
China
I wonder why RCA input has so much higher distortion than XLR input, normally both should be almost same with XLR having advantage in CMRR.
In order to save costs or for other reasons, the developers seem to have decided to use the same circuit for both input gain and unbalanced-balanced conversion.
Reactions: wje
bunkbail
Meh. Schiit Freya S is better than this.
Matias
São Paulo, Brazil
Very nice! Would love to see the same measurements of a Schiit Freya S for comparison.
pozz
Слава Україні
Editor
Great work Wolf.
Imran Zafar
Not much detail about features on eBay. Can the RCA input be configured at HT Bypass with XLR out?
WolfX-700
WolfX-700
China
Max
France
Great work, good review, thanks a lot @WolfX-700 ! A good preamplifier in low/mid-budget price, nice to see !
Max
France
I'm surprised (in a good way) by the near perfect amplitude match between the left and the right channels. Impressive.
Veri
Great contribution btw, @WolfX-700
Cortes
I apologize by the silly question (I've the intuition that it is), but what this thing is useful for?. It's not that any decent DAC with volume control can do the same?.
Veri
It's purely analog for one, so plays well with powerful poweramps. If you rely on digital control and accidentally blast at max volume, your speakers might fry.
Expensive pre-amps also have very accurate steps within the volume control as has been measured here.
