Measurements of Sonore microRendu Streamer
Sal1950
The Chicago Crusher
Central Fl
Noise from a PC (or other computing device, Pi or whatever) can be carried along in the ground connection, plus I suppose RF noise on the data/PSU lines. This why I use an Intona galvanic isolator.
That's why I'm using Toslink. ;)
Sal1950
The Chicago Crusher
Central Fl
LulaNord
Hi...i am a new user here. As per my knowledge if the microRendu causes the iFi DAC to output a higher analog level with the same digital level source, there are two options:The digital signal level has been increased by the microRendu - meaning it isn't transparent passing data - meaning, to me if a full scale source signal is processed it will be digitally clipped. And Testing error.Can you digitally loop your source to the analyzer, and while transmitting the same source digital signal, compare the numerical levels of what would be "direct to iFi" vs "massaged by the microRendu"?
printed circuit assembly
RayDunzl
Central Scrutinizer
Riverview FL
Maybe you haven't read far enough, but that was resolved - cockpit error... see post #27
jtwrace
Orlando, FL
I am not home so can't look up model. But it is nade by Leader. It is 20+ years old linear power supply. I am not sure if it is still made.
Thanks!
Found a picture of it on my workbench for when I tested the grounding box:
It is the box on the left. I actually have three different ones so it may have been one of them but all are in the same series.
Blumlein 88
And now, it is obvious with one picture why your results were no good. You have used a skewed power cord plug. How many times must it be repeated, everything matters. Your skewed cord plug should be 90 degrees to the earth's magnetic field or parallel to it. You can't get results at a level of sensitivity that a grounding box works with such sloppy implementation. All that expensive test gear becomes useless from simple sloppiness. Oh, and is it okay to stack your Stax like that?
Don Hills
Wellington, New Zealand
What's the box behind it with all the power cords plugged into it?
And you need to replace the power cord from the wall socket, it's far too flimsy and cheap. ;)
DonH56
Monument, CO
Looks like a standard UPS.
Wood looks nice for a workbench, but one thing I would seriously recommend is getting a good antistatic mat that covers it. At these frequencies and for consumer stuff ESD probably isn't a huge concern, but you're obviously not in Colorado. Dry air, lots of static.
Which perhaps explains a few of my posts... ;)
NO, it is a magic box with ultra-super-cap energy generator using rare, radical free insulated wires. I hope to market it one day for say $20,000.
It is not an electronic workbench Don although I have done some light work there. It is a bench for measuring audio equipment right now. I am debating where you build my electronics bench as this place is highly visible in our home. I have space in basement but don't want to work there as it is away from family....
