Measuring Speaker and Headphone Outputs With Focusrite Scarlet 2i2 v3
Helicopter
Michigan
I would like to measure the output of some tube amps using my 2i2. I am considering getting an oscilloscope too (<$500), but I don't really know if it will be useful.
I am wondering if I have a good dummy load circuit in mind, and how to calculate the values of the series resistors for the measurement parallel circuit.
I want to do a sine wave, multi-tone, etc. I'm pretty sure I won't have any trouble getting tests signals into the amps.
I was thinking about getting an oscilloscope with a budget of about $500 retail, so I would like advice on if that is likely to compliment my 2i2 in this application, and if so, which scope would be recommended.
I'll post pictures from my phone in a moment.
Thanks in advance for the help!
Helicopter
Helicopter
Michigan
Here are the circuits i am evaluating.
Helicopter
Helicopter
Michigan
Here are the amps. Shuguang audio SG-845-7 SET amp and Darkvoice 336SE
Helicopter
Helicopter
Michigan
Sorry if my TS-M connector drawings are too masculine.
Each dummy load would be duplicated; for the speaker load, the whole thing; for the headphone load, the part right after the headphone output connector so it can Y to the two inputs on the 2i2.
I know the series resistors for the measurement circuit are going to be different for TS vs XLR because of how the 2i2 treats them differently, so I'd like to know if XLRs are going to be better, or if TS connectors are better going into the 2i2.
Blumlein 88
You probably want to use the TRS into the 2i2 because the XLR goes into the microphone section. The Line section would handle higher voltages.
What you have drawn for speakers actually would not work to show you anything.
You could have your dummy load. In parallel with it you can have a resistor divider pair and tap it to get voltage that is low enough not to damage the 2i2 line inputs. For the low powered amps for instance you could parallel a series pair of 1 kohm and 100 ohm. Tap across the 100 ohm resistor with the inputs to the 2i2. Multiply by 11 to get the real value. You would be safe to amps of almost 60 watts with this setup. You would need to change the resistor pair for higher power items not to damage the 2i2.
P_M
San Francisco Bay Area, CA
@Helicopter
you need a specturm analyszer to test amp performance, not an oscilloscope. For some specific type of troubleshooting where you might want to see the waveform like for crossover distortion in AB or push-pull amps or flat topping of waves or ringing then an oscilloscope would come handy.
In any case, I recommend you install a basic test software like ARTA or REW and read the instructions that come with it. That will help you setup a simple jig for measurements. As for dummy speaker load I think amirm uses one, just search the forum.
GeorgeBynum
Greenville SC USA
@Helicopter
Although not precision, I've used kitchen irons as dummy loads; a typical 1200 watt iron is 12 ohms in the USA (120V power). 2 of them in parallel give 6 ohms, a reasonable real load. NOTE use is intermittent; you DO NOT want the thermostat opening with the amp at full power.
I personally had access to scrapped returns years ago, and removed the thermostats on 2.
An electric stove element, commonly 4800W, will be 3 ohms in the USA.
AnalogSteph
.de
Yes, the L-pad with two resistors is the way to go.
Actually, 4 - include a parallel of the same values between amplifier output ground and the "cold" line for balanced impedances.
1. out+ -> R1 -> ...
a) ... hot @ cable
b) .... R2 --> out-ground
2. out-ground --> R3 = R1||R2 --> cold @ cable
Note: Voltage equivalent to 60 W into 8 ohms will dissipate over 0.4 W in 1.1 kOhms. I'd go a tad higher in values in order to be able to use ordinary 1/4W metal film types (which in turn shouldn't be seeing more than half rated power), maybe a factor of 5-10. Do keep R1||R2 well below 1 kOhm if you can - make up R1 from two parallel or series if need be.
(P_total = V² / (R1 + R2) = P_amp_8ohm * 8 / (R1 + R2); P_R1 = P_total * R1/(R1+R2), P_R2 analogous.)
Note 2: You need a slightly different attenuator setup when measuring amplifiers with bridged (BTL) outputs, so you must always know whether the amplifier's negative output is ground referenced or not.
For a BTL output, you would need a double (balanced) L-pad:
a) ... hot @ cable
b) .... R2 --> shield @ cable
2. out- -> R3=R1 -> ...
a) ... cold @ cable
b) .... R4=R2 --> shield @ cable
This should actually simplify to the non-BTL version if out- = out-ground connects to shield @ cable via the audio interface. So I guess this one could be used for both kinds of outputs.
Note 3: I don't actually see a problem with using the mic input assuming attenuation is increased accordingly (e.g. R1 = R3 = 15k || 15k, R2 = R4 = 470 ohm, should be good for max +9 dBu from a 200 Wpc output). It is not unusual to be seeing a line input being created internally by just putting some e.g. 22 kOhm resistors in series with the mic input, which in turn has a 2-3 kOhm input impedance and forms an L-pad this way. Our external L-pad with a couple hundred ohms of output impedance would be less noisy for one. If in doubt, evaluate both. The device specs may give some hints.
Helicopter
Helicopter
Michigan
It does have the best specs with the mic input, so I can use that.
MICROPHONE INPUTS
Frequency Response 20Hz - 20kHz ± 0.1dB
Dynamic Range 111dB (A-weighted)
THD+N<0.0012%
Noise EIN -128dBu (A-weighted)
Maximum Input Level 9dBu (at minimum gain)
Gain Range 56dB
Impedance 3kΩ
I think that means about 2 volts to fry it with the input volume all the way down and 1 mV with the volume up. I'm not sure if that's right because I don't know if the 9bBu is referenced to 300Ω or 3kΩ, and I didn't check my math.
4 resistors... do you mean like this?
Do I need another resistor on the bridge between +/-?
If not I could do 1 circuit like the schematic for each channel, with 4 ohm resistors (100W, irons, something like that) and then maybe pairs of 3 500 ohm metal films so the amp sees about 8 ohms and you get 3Kohm limiting current into the 2i2.
I have 4 100W 4 ohm resistors, so it would be great if the circuit without a resistor on the bridge would work, but I don't need to make it work with the stuff I have. I'm pretty sure there's a Parts Express order between me and this dummy load anyway.
Does the input of the 2i2 actually behave like a 3 Kohm resistor, drawing only half the current it would if you shorted the XLR after 3Kohms of resistors?
I found Amir's Darkvoice review
https://www.audiosciencereview.com/...ements-of-darkvoice-336se-headphone-amp.6549/
and his plans to review the Loxjie P20
https://www.audiosciencereview.com/...-be-reviewed-by-amir.4800/page-20#post-458293
Now I am more interested in measuring the Shuguang SG-845-7 with this load.
AnalogSteph
.de
+9 dBu always is 2.18 Vrms whatever happens.
I would expect best distortion performance for a gain in the 20-30 dB range (it typically degrades near unity somewhat). So you could try R1 = 22 kOhm, R2 = 330 ohm or thereabouts.
Nyet.
Your "attenuator" makes no sense at all like that. (Homework: Explain why.)
You know how an XLR cable is normally wired up, right?
Hot --> pin 2
Cold --> pin 3
Shield --> pin 1
The attenuator is arguably best drawn with conductors in the order of:
Hot
Shield
Cold
Now try that with the pseudo-schematic given earlier, which I'll also paraphrase in plain German:
Output (+) connects to R1 in series. After R1, the Hot connection continues, and R2 branches off going to Shield.
Output (-) does much the same, except it's the Cold connection continuing this time.
Yes, the attenuator has two input connections and three output connections. Shield does not actually go all the way to the amplifier.
Your dummy load always just connects directly to the output, in parallel to the attenuator. It can be left off in testing as long as the amplifier does not require a load for stability (this is generally not an issue but can be in obscure low feedback tube designs).
You might consider making a small circuit board to not only hold the hold the attenuator but also connect the dummy load and facilitate 4/8 ohm switching. Something with sturdy wire terminals for input, male XLR jacks for output, and wires dangling off to connect to your dummy load(s).
somebodyelse
An example with pictures showing a simple dummy load and attenuator with an RCA connection. this thread covers similar ground, but with a switched attenuator for easier use at different signal levels. The series of articles starting here is worth a look too - part 4 covers some of the interface options available to protect your soundcard, and part 6 has an example balanced attenuator that you could use in place of the single ended one in the first link.
Helicopter
Helicopter
Michigan
This confirms my understanding of dBu. Good point on optimizing attenuation at expected performance peak.
Nyet.
I didn't think it looked right. I was trying to understand where you would put 4 resistors. With no resistor on the link from + to -, you short the output to the 2i2 and I don't think you would actually divide the voltage. So you would just be attenuating current, shorting, and attenuating some more; the bigger problem is the short, which is why it wouldn't work at all.
Hot --> pin 2
Cold --> pin 3
Shield --> pin 1
Yes.
Hot
Shield
Cold
OK. Thank you.
Lots of good stuff here. Thank you.
Helicopter
Helicopter
Michigan
4 resistors would work like this:
Putting wires, lugs, or aligator clips for the 8 ohm resistor in this configuration should give versatility and allow the use of inexpensive metal film resistors for the 11K and 330 ohm resistors.
I think the result would be pretty similar with something like this:
Although this would not give versatility, and all of the resistors would need to be high current.
Am I understanding the wiring correctly for XLRM Socket, with hot (+) tied to common ground?
I know the voltage divider doesn't need to be balanced as one resistor on one side of the circuit limits current to both sides, but I prefer this layout, and testing this morning with a DC load indicated it shouldn't change the outcome compared to a traditional voltage divider. Just add the values of the 4 or 11K resistors to get your R1 value of 8 or 22K.
AnalogSteph
.de
I meant 4 resistors plus dummy load resistors, in case that wasn't clear.
So there is two of R1 and R2 each for the hot and cold side, respectively.
EDIT: OK, screw it, here's a schematic:
AnalogSteph
.de
Ahh. That makes perfect sense. Put the shield right in the middle of the circiut.
I mean, you obviously wouldn't build it looking quite like that since the hot and cold wires will be twisted (as would the input wiring, generally), but it's good for illustration. The real thing has to be kind of folded up.
Helicopter
Helicopter
Michigan
Yeah. I just mean conceptually, and electrically. I was trying to figure out what to do with the shield other than nothing, like those crummy commercial products in the other thread where you posted your drawing. Your schematic is an elegant solution because the shield remains at the center of the AC wave through its entire positive, to zero to negative path. If something is not perfectly matched on one side due to tolerance, interference, the shield should help there.
In short, it is in the circuit, but it will not draw any current, which is important.
AnalogSteph
.de
Exactly, since shield in general already connects to the amplifier's input side.
Incidentally, in case of a single-ended output (OUT - = SHIELD), the attenuator effectively simplifies to an unbalanced attenuator with an impedance balancing resistor in the cold lead.
Helicopter
Helicopter
Michigan
Finally made this attenuator box. I went 15kOhm/470Ohm for R1&R2/R3&R4. I made 2 channels with 3 SpeakOn connectors in parallel on each side so I can connect an amp, speaker or other load, and a multimeter if I want.
Next time I need to do D mounts in a project box I will use a vise... some of the big 15/16 holes got a little elongated.
