Merging Technologies Anubis DAC/ADC with build-in room correction
Music1969
@amirm a long while ago you mentioned you have a lead for getting a Merging Anubis.
Still have that lead?
dasdoing
dasdoing
Salvador-Bahia-Brasil
that would be intresting
Sokel
Is it the one we all asking for?
Enough inputs and outputs (expendable),Room correction,EQ,routing,decent measurements,etc?
Definitely on the watch list.
Kal Rubinson
Industry Insider
NYC
The outputs are "expandable" only if you add another compatible device like a Hapi.
Sokel
Yes,I thought that should be straightforward as long as someone visits their website but is good to discriminate it.
And it's not the only extra they offer.
Music1969
15 band parametric EQ also built-in
Can be separate for left and right channels if required
Sokel
I wonder how things like this are not mentioned more frequently here,seems that it's not the only one.
(even if after Dr Toole's post I will think twice of using EQ carelessly from now on)
Music1969
Probably because it is very expensive.
Ravenna can be a real pain to get working reliably too - it is not plug and play like a USB DAC
And maybe it doesnt measure well? Thats why I asked amir if he can measure
Maybe someone in the USA can send him one
Sokel
That's debatable,it's in the price range of RME pro and if it's of the same quality and measures decently is not only fair but a real bargain for what it offers.
Yep,I would really like to see it on Amir's bench.
Music1969
Don't understimate the complexity of Ravenna vs USB DAC (RME)
The last 20 pages of the Anubis thread on the popular pro audio forum, is basically all Ravenna troubleshooting
Absolutely not plug and play
And forget about playing straight from iPhone/iPad or Android to the Anubis
Marc v E
The Netherlands (Holland)
For the price of the Merging player you can almost buy d&d c8.
Correction: you can buy the d&d 8c and would have an extra 1500 euros to spend on a source.
