MiniDSP 2x4 advanced plugin tutorial: integrating anechoic EQ filters
ethernode
Hello everyone; i'm relatively new to this, and struggled a bit to setup, so i thought i would share what i learnt.
To put things into context, i had the opportunity to buy Kef LS50 (1st gen) for a very low price (380€) and i own a used MiniDSP 2x4 (non-HD, the 48 Khz one, which i bought used for ~70€) and an SVS-SB1000 sub. I wanted to implement the optimized anechoic EQ settings that @Maiky76 kindly provided here, but it wasn't that easy as a beginner.
The goal for this tutorial is to help newbies like myself deploy optimized EQ filters sometimes found on this forum (like the one below) on this MiniDSP platform.
Code:
Preamp: -0.9 dB
Filter 1: ON HighPass Fc 75.31,    0.00,    1.48
Filter 2: ON HighPass Fc 90.38,    0.00,    0.74
Filter 3: ON PK Fc 152.65,    -3.17,    0.78
Filter 4: ON PK Fc 550.00,    1.40,    3.72
Filter 5: ON PK Fc 830.00,    -2.40,    1.83
Filter 6: ON PK Fc 1224.00,    -1.34,    9.45
Filter 7: ON PK Fc 1609.00,    2.11,    2.65
Filter 8: ON PK Fc 2764.00,    -2.80,    1.35
Filter 9: ON PK Fc 4747.00,    -3.40,    3.00
As reminder (this is common knowledge, but that wasn't clear to me so i'll repeat it for beginners like me), we want to apply these mostly for correcting frequency response above the schroeder frequency where the perceived sound is mostly dictated by the speaker behaviour (below this frequency, the room is mostly affecting sound so there's little one can do without measuring your own room). The filters above have been computed based on frequency response measurements achieved in an anechoic chamber or alternative, room-independant measurements (like the Klippel system), with an algorithm that targets to maximize the Harman speaker preference score [reference needed].
It was not that straightforward to apply the filters above, notably because
- MiniDSP seems to have released their 2x4 advanced "plugin" relatively late, so most information regarding the use of the MiniDSP 2x4 is kind of outdated (e.g. the REW UI assumes 6 BQ and not 5, tutorials are for other plugins, etc ...)
- the MiniDSP 2x4 has 5 band PEQs, not 9, so a splitting strategy must be defined
- the crossover parameters (HighPass filters 1 and 2) described above need to be input as biquads (advanced mode)
- although i already did auto-EQ with REW, i did not know how to convert manual/custom PEQ parameters in REW into biquads usable into the MiniDSP
The MiniDSP 2x4 plugin specsheet states that there is one 5-band PEQs available per input and output channel (5 biquads each), as well as 4 LPF/HPF block that consists of 8 PEQs (confirmed by MiniDSP support).
Based on the above
- i applied the preamp gain in the first blocks
- i routed Left into output 1, routed RIght into output 3, output 2 gets L+R summed signal for the sub
- i placed filters 5-9 into the the downstream 5-band PEQ blocks, and filters 1-4 into the LPF+HPF block
This should leave 4 biquads after the matrix and 5 before (full band) for room correction. Below is the setup:
To generate the biquads using REW, i followed the following steps:
1. Click "EQ"
2. Select miniDSP eq type, click "EQ Filters"
3. Insert the high frequency components (only 5)
4. Export coefficients to file
5. Do the same for the crossover block, but the exported file should be completed with 2 disabled biquads (the MiniDSP expects exactly 8 biquads), which i did by copy-pasting (the files are available as attachments)
6. Spin up the MiniDSP plugin UI, configure the routing
7. Select the crossover block, click "Advanced", copy-paste the xo_8bq.txt file contents, hit "Process" -- the UI does not offer an "Import REW file" button here -- which is also why i had to fiddle with it to reach 8 biquads; do this also on the crossover of Output 3
8. Move on to the PEQ - output 1 block, click "Import REW File", import "after_xo_bq.txt"
9. Click "Copy to output 3"
10. Apply a 24 dB/octobe Low Pass LR filter on Output 2 (sub)
11. Apply the -0,9 dB gain on the Input Gain block
I included the full XML settings file for convenience.
Things i did not understand:
- could i have used any other 48 Khz Equalizer in the REW window (to avoid having to split the biquads in two steps) ? Or will REW possibly apply format tweaks on the export ? Why is REW limiting MiniDSP EQ to 6 band only ?
- not sure how to configure the low pass for the sub to match the modified high pass
Feel free to feedback if you know better ways to achieve the above ! I hope this helps someone.
  • xo_8bq.txt
  • after_xo_5bq.txt
Purité Audio
Industry Insider
Barrowmaster
London
It is the frequencies below Schroeder that can cause the really severe problems if you have a ’traditionally’ furnished room I would leave the higher stuff alone.
ethernode
ethernode
I understand, but can you elaborate why ? Note that i do not intend to correct high frequencies with in-room measurements.
abdo123
Brussels, Belgium
Feel free to correct frequencies above 200Hz with anechoic measurements. it's actually recommended. I'm a little occupied right now, I will reply thoroughly in a bit to answer your questions.
Triliza
Europe
Good of you to post the steps, I am also fiddling with filters (using Moode/CamillaDSP) and it is challenging to get it done starting from the ground up, many things to learn.
Regarding applying filters on anechoic measurement, I'd like also to know why it matters at what frequencies you apply the filters, I was under the impression you apply them whenever they are needed to flat the curve (as much that is possible for each speaker, without messing other metrics), regardless of the frequency.
abdo123
Brussels, Belgium
I simulated a crossover and it seems Butterworth 12db/oct highpass at 80Hz for the LS50 and Linkwitz-Riley 24db/oct lowpass at 80Hz for the sub seem to sum pretty nicely. If you use the MiniDSP to apply the lowpass, then make sure to disable the built-in lowpass of the subwoofer (read the manual).
abdo123
Brussels, Belgium
Also, these Maiky’s filters are weird. I would drop everything below the 550Hz one.
With the crossover i supplied the response should sum to anechoicly flat without them anyway below 500Hz.
abdo123
Brussels, Belgium
Other than these two pieces of advice, I would say you’re on the right track!
Tinker further to your liking and enjoy the journey!
ethernode
ethernode
Nice, thanks ! What about a 100 Hz crossover ?
Yes sub is in LFE already ;)
ethernode
ethernode
I don't know how @Maiky76 did generate the crossover, he did not say how, but apparently he took the filters without the high pass, then determined a custom high pass that allows to keep the lowest frequency filters (vs the the 24 dB LR high pass I was about to use).
abdo123
Brussels, Belgium
Yeah I think these filters are back in the old days before Maiky optimized the algorithm, i would just take the filter at 550Hz and above.
ethernode
ethernode
Btw my sub is sealed, shouldn't it matter for the low pass slope ?
ethernode
ethernode
To satisfy your curiousity about the 100Hz crossover.
Thanks for spending the time !
I see a larger bump on the 100 Hz one, and horizontal directivity seems smoother with 80 Hz xover, but i'm not sure because the scale is not the same (i opened both images in 2 tabs to compare) -- not to be picky !
What's your analysis ?
I'm guessing the phase should just be ignored (in real life i should time-correct it, right ?)
abdo123
Brussels, Belgium
stick with the 80Hz unless you're listening at further than 1-2 meters.
ethernode
ethernode
Are you saying that because at high power the LS50 will suffer producing 80 Hz ?
abdo123
Brussels, Belgium
pretty much. I have a 5.25 inch woofer in my living room crossed at 80Hz and i think it's fine at short distances. I definitely don't see it moving.
ethernode
ethernode
@abdo123 just found your post where you said you recommend 95hz cover, do you still think that ?
Would you mind sharing some project file for VituixCAD so that I can try to play with the different HP/LP filters and xover freq ? Or maybe I should just try all available on the minidsp and measure + listen...
