Volume issue with fw v1.29 & volumio v1.073 confirmed by miniDSP:
Hi Koos,
Let's see how we can help
You updated Volumio to the latest version? You will need to do so first to be able to get the new volume control working.
Hoping this info helps and feel free to contact us if you have further questions.
Best Regards
miniDSP DevTeam
Hi minidsp,
Thank you for your response. No, I haven’t updated Volumio, since there is no update available for my device (relative new SHD, delivered in februari).
Regards, Koos
Hi Koos,
Our team has tested Volumio 1.073 with a Neo3 unit and it worked perfectly. Is it possible for you to tell us more about your setup? Did you connect the internet via wireless dongle or LAN? Have you try to reset your SHD to default settings?
Best Regards
miniDSP DevTeam
Can you confirm that you tested this with FW v1.29?
If you can confirm this, I’ll reset the device to default settings and will test again. I’m using LAN by the way.
Regards, Koos
Hi Koos,
Please disregard the previous email. We tested the unit with FW v1.29 again and we ended up having the same issue with you. Once we downgraded it back to FW V1.28, the volume control became working again. Attached is the bin file of FW v1.28. Please download it and flash it back and see if it works for your unit. Sorry for any inconvenience caused.
Best Regards
miniDSP DevTeam
No worries, perfect, thanks for verifying. I’ll downgrade to v1.28 for the time being. Any news when to expect an updated Volumio build?
Koos
