I'm currently having some issues with the NAD M10 v2 which I'm using with pre-outs to an external amp. It's in use in the main family living room area for mixed usage with the TV. So I'm strongly considering getting the MiniDSP SHD, but ease of usability once everything is setup is fairly important. I'm planning on running optical out from the LG C1 to the MiniDSP to the power amp. I had a few concerns before purchasing.
- Will I be able to control the volume of the SHD with the LG remote? Looks like it is possible with the C1 and optical out, but wanted to make sure it would work with the SHD.
- Is the best way to set a max volume by adjusting the output in the plugin?
- The NAD unit had a trigger out, but sadly the SHD does not. I do have a Furman Elite-15 PFi power conditioner that has switched outlets with trigger in & trigger out. Any way I can make use of that?
