- Joined
- Jun 10, 2018
- Messages
- 6,243
- Likes
- 9,377
This choice shows up in various places:
1. Many DAC's, including several reviewed here.
2. Most implementations of SOX
3. Rephase (default is minimum phase.)
My understanding is linear phase filters have pre-ringing. Minimum filters put all the ringing after the pulse. When lossy audio compression was under heavy development pre-ringing was often discussed and it could be identified in double blind testing. At the time developers were trying to reduce pre-ringing.
I haven't done any blind testing, but there appears to be a certain harshness in loud and high notes of some female vocalists which goes away when the DAC is set for minimum phase. The Topping D30 has this problem, in my opinion. When I use my Topping DX3 Pro with a linear phase filter, it sounds just like the D30. Switch to a minimum phase filter and the harshness goes away. This was noted on both LSR305 Mk II's and LS50's powered by a Crown XLS 1502. The difference is subtler wiith my Grace M9XX which might mean something else is going on.
So, what kind of filters should we be using, or is this from the marketing department? Does it make a difference if the application is a DAC, SOX or Rephase? Note the JRiver implementation of SOX is fixed, probably with linear phase and they are adamant about not making it configurable.
