Mobile phones and sound quality
Soniclife
GSM Arena usually have some measured data on the headphone out in their reviews. Nobody seems to want to measure output impedance, sadly.
Not here :). I measured mine:
S63tu
Only phones I've heard that were good sounding were the LGV10 and 20. My girl has the V30, but I've yet to listen...finding this information out has been difficult for me.
I used my Note 8 the other day for the first time to listen to music. Such a horrid experience. I haven't used an unrooted android phone for audio in quite some time, and I was immediately reminded why. I did enjoy the LG phones audio capabilities very much I must admit. The Samsung phones, in my experience, are very underpowered, and I don't enjoy the sound at all. I need viper4android to enjoy music on this device. Just not worth rooting anymore though since I have dedicated daps.
Snafu
I got Oppo Reno and it sounds pretty good (Tidal app) even with Oppo PM3 headphones. Does anyone know what kind of dac it has ?
all info i found was:
3.5mm jack Yes / Active noise cancellation with dedicated mic
24-bit/192kHz audio
If anyone knows measurements, that would be great. Thanks
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
The main reason I got my LGg8 was for the emphasis on audio.
Headphone jack, very good DAC... I don't care about the camera... I've been more than happy with the sound quality of my phone.
It's worth the extra money to me for the flexibility it gives to effectively walk around with a desktop quality DAC (by measurements).
vert
Switzerland
I will be replacing my smartphone soon. Currently have a three-year old Xperia. Are the tests on gsmarena trustworthy? As per them Samsungs top all categories including audio quality. As much as I hated my wife's Samsung a few years ago they seem to have gone a long way,again if that site's reviews are to be trusted.
Snafu
Samsung... Schiit of phones and everything... :D
samsung hard drive, fails, printer, fails, tv fails, display fails. Thanks but no f'n way i'm gonna even think samsung labeled product.
didn't they have their own commercial push system in their tv's ?
vert
Switzerland
This site typically conducts a limited performance analysis of the audio subsystems of the devices they review:
https://www.gsmarena.com
Yep... and according to them Samsungs have the best audio performance... some are as good but not better, or marginally. I'm oversimplifying, but that was what came out, by and large, after reading a few reviews of different phones.
ernestcarl
I used to use portable DAC/amps with my smartphone religiously. I've all but given up on that now as the inconvenience experienced is just not worth it. But yeah, I will always try to find reviews first before committing to different smartphone...
Berwhale
Most of the time reviews of mobiles focus on screen, camera, power, weight, whatever but rarely on sound quality.
Most of the time one can’t even find out what DAC has been used.
Found and exception to this rule.
https://smartphones.gadgethacks.com/how-to/top-4-phones-for-music-lovers-audiophiles-0175956/
Why not just take the phone out of the equation with some decent software and a Bluetooth DAC/Amp with LDAC?
I use: https://www.extreamsd.com/index.php/products/usb-audio-player-pro
And: https://drop.com/buy/radsone-earstudio-es100
Note that UAPP will also work directly with DAC in supported phone (bypassing Android Audio components), there's a list of supported phones here: https://www.extreamsd.com/index.php/hires-audio-driver
Julf
Amsterdam, The Netherlands
Why would you, if the phone is more than good enough?
SIY
Alfred, NY
The iPhone 7 and 7 Plus might boast superior audio when compared to Apple's previous offerings, but that only applies to the built-in speaker quality. And besides, iPhone 7 models were immediately ruled out because they don't have a headphone jack, which means that music can only be listened to over Bluetooth or via the Lightning port. Both of these conduits are severely lacking when compared to audio from a 3.5 mm jack.
So they didn't bother looking at the iPhone plus Lightning-to-3.5mm dongle, which is a great pity given the superb performance.
bravomail
old post and old article. GSMarena stopped testing audio too. I found one for Note 9. Not for Note 10 or S10.
Berwhale
I have several personal reasons...
I use a phone for many purposes and I don't want my choice of phone constrained by the audio components within in it (e.g. many new flagship phones do not have a 3.5mm jack and none have the 2.5mm balanced jack for my IEMs)
I find that cables wear out very quickly when plugged straight into a phone - I commute for 2 hours per day on foot and via train, so sometimes the phone is in my hand, other times it's in my pocket, having the phone joined to my ears via a cable is a PITA.
I can pair my ES100 with both my Note 9 and my Huawei tablet (which doesn't have 3.5mm audio).
