monolith m-10 v2 or svs sb-2000
SlamTaz
i know m-10 is ported and svs is sealed and after a bit of research (e.g. also looked at subwoofer comparison), i've narrowed down my choice between these 2 only, so please let me know your thoughts as to which one of these 2 you'd choose. im thinking that the former can be sealed if needed and that the price difference i can get them for is about usd$50 only.
also, this will be used with a pair of elac dbr62 and powered by sabaj a30a in a 1800 sqft +/- room for about 80% or more music and maybe 20% or less movies.
tia
Steve Dallas
A Whole Other Country
I have no actual experience with Monolith subs. I do own two SVS SB-2000 subs and quite like them. Both of mine developed a hiss over time that I could hear from my listening position, about 8' away. SVS sent me new plate amps with no drama at all, which solved the problem, and the problem has remained solved.
The SB-2000 is capable of going very low with room reinforcement. These are mine, crossed at 80Hz to my Revel F206 small towers:
3125b
Germany
Both will do a good job and be able to play a lot louder than the speakers at crossover.
The Monolith, despite being the smallest in its series, is rather big and heavy.
However despite being ported it likely has lower group delay, SVS always messes that up.
