Most important channel and speakers in Home Theater
Most important channel and speaker in Home Theater
gags11
What’s most important for HT, center, fronts, or the rest?
The reason I post this, I think center is by far the most important channel and speaker, imo. Would like to here opinions on this.
if so, would love to see Amir measure and compile some center channel measurements.
Aerith Gainsborough
L C R are the most important ones for movies, yes. They get most of the signal and oftentimes the center is working on it's own during dialogue scenes.
Blumlein 88
I think the fronts are more important than the center though the center is important. You can have great clear dialogue on the center and obviously that is important, but if the front pair are substandard everything happens in a smaller, less detailed, less enveloping space. The envelopment is what makes for an immersive experience and the center doesn't do much for that. The surrounds finish the envelopment, but the front pair must be good for it to work well overall I find.
peng
For speakers, the center is important in terms of the ability to produce clear dialogue to your mlp, and also power handling because for movies, more often that not, there are higher power demand on the center channel speaker, all else being equal.
Other than that the front left/right, imo are more important in terms of accuracy, i.e. lower distortion, better FR, on and off axis etc., for overall enjoyment.
retro
I have always preferred phantom center setups. Even when I used identical LCR speakers. IMO, you loose the soundstage and depth that are present in so many productions when you use a center. Even more so in music and concert BluRays/DVD's..
If you're seated offside from best listening position, then of course a center can help lock the dialogue. Not a problem for me though, cause I'm always in the sweetspot..:cool:
Aerith Gainsborough
Center speaker is only relevant if more than 1 person watches the movie because then, no one sits in the focal point of the sonic field generators. :p
G
gags11
For newer formats like Dolby or DTS, I think dialog comes imbedded in the center channel only. It needs to be down mixed to get that from the fronts. This was my understanding.
In addition, I have noticed that the center handles way more than just dialog. It handles significant amount of music and sound passages, but of course it depends on the original mix. In some cases the front speakers are producing what seems like background sound and passages. And sometimes devoid of midrange. Of course, this is again dependent on the mix. I’m referring to anything with original 5.1 and up, DTS or Dolby.
MakeMineVinyl
Santa Fe, NM
I totally agree with this. Although LCR was the original concept of 'stereo' in the early 1950s (the compromise of 2 channels came later in that decade), I have found repeatedly that the presence of an active center channel completely destroys stereo imaging, depth and width. Although the center speaker was originally intended to provide just those qualities in the early 1950s (and many if not most original music master recordings were 3 channel), it doesn't work in practice. The presence of a center speaker calls attention to itself.
For home theater where many people are off-axis, and obviously in a movie theater where most people are off-axis, a discrete center makes total sense.
Fun fact: originally (the early 1950s) the word 'stereo' was supposed to be restricted to 3 channel (LCR) recording - 'binaural' was reserved for 2 channel reproduction.
FrantzM
A center channel is ESSENTIAL for movies. The oft-repeated, but not factual point, that phantom center channel is enough doesn't hold scrutiny. Someone posted some times ago, on ASR, the the FR differences between phantom and discrete center speaker. It wasn't even close, to use an expression dear to audiophiles.
I disagree also with the , again too often repeated point, that the center channel carries most of the sound. No! It doesn't, in my experience, I watch about a movie or more per day, it (center) carries part of the sound scene but mostly the dialogue.. The rest is carried by the L and R.. As for surround it is good to have similar speakers but ... For Atmos, I make do with a pair of Bose 161 on the ceiling, it seems to work. I will go toward a pair or more of LSR305 on the ceilings .. when I move to 708 up front ... :).
Peace...
Thomas savage
The Watchman
uk, taunton
Assuming the most important is the differing potential over a stereo 2 channel setup its got to be the center channel or the subwoofer.
I voted subwoofer as to me thats the biggest upgrade if I were to chose between a 2.1 setup and a 3.0 setup .
I'm perfectly happy with voice over stereo myself.
Aerith Gainsborough
That depends on how one treats their family, housemates or guests... there is always a sweet spot or area. ;)
Sure, let the guest sit in it when you want to show off.
My friend did that with me and I immediately fell in love with the Focal sound. :D
When we watch, we both sit at the sides of the center, so both our heads are as close as can be (at least half the head), instead of one sitting in center and the other off center. Sharing the spot, so to speak.
Correct.
Most AVRs do that automatically when Center is set to "none".
In my nearfield setup, I notice no difference with or without a center. It may be more relevant for couch setups, when the mains are further apart but with my Focals, I often get the eerie effect that the voice comes directly out of the screen.
If you have the ability to let the big boy off the chain, definitely.
Nothing will have that much impact (pun intended) during action scenes.
Teeter
Janesville, WI
I watch a lot of DD movies and for me, the Center Speaker is the most important...........long short. For MP3 music, I set the AVR on Multi Channel.
Senior NEET Engineer
San Diego
Subwoofer for me. I would be happy with $2000 subwoofers and $150 speakers, but not the other way around. There's a minimum cost for ULF subs.
CJPopovich
Front L&R. Prefer phantom center most of the time (not always). IMO you can have a rewarding experience with good L&R's and phantom center, but if you ditch the L&R you're listening to an expensive soundbar. Pass.
Chrispy
PNW
Are we talking a third speaker (identical LCR) or compromised centers? :)
Beershaun
Front left/right are most important to me. If I had to pick one thing to add to my TV only setup first it is left and right speakers. (Which is what I did in real life). Everything else comes after that.
JSmith
Algol Perseus
I don't think I've seen a system running surrounds and no front L/R... ;)
Have seen a number running no centre though like 4.0/1 etc.
JSmith
