"Muscular" floorstanding speakers for 1500 euros
Bleib
Sweden
Canton GLE90
Monitor Audio floorstanders, silver
Emotiva Airmotiv T2+
I would look into these
Burgunder
These might fit
Chrispy
PNW
Curious, what is the amplification available for the speakers?
Talisman
Talisman
Milano Italy
I have already bought and saved two sabaj A8 monoblocks 250watt into 8ohm. I will be using a Loxjie D40 as dac and preamp
Chrispy
PNW
Well that should suffice for most uses :) Back to the JBL 190 for a sec, why doesn't it fit the bill particularly?
PatentLawyer
Deep in the Soundstage
Something from Arendal?
Talisman
Talisman
Milano Italy
I've seen a not exactly brilliant review of the jbl a180 little brother, so I'm not inclined to buy this line of towers, moreover I don't like it very much aesthetically
Chrispy
PNW
C'mon, even TAS liked it they even refered to it as a "brawny performer that shows its muscles" :) Generally I've seen good user comments....but no klippel tests.
Feyire
Netherlands
Sokel
The cheapest towers are 1899 a pair, so slightly above the specified budget, but certainly a worthy consideration for just a bit more money.
The 4 5.5" woofers comes close to a 10-11" driver but one of them has to be for mids only,so it's lower than that.
Considering the xover is at 120Hz,also not inclines "big" sound.Their size is also modest.
Maybe I'm wrong,but as a skilled friend here explained lower mid's "mouth" has to be adequate to give that "big" feeling.
Feyire
Netherlands
If you want "big" feeling sound, then you'll mate the floor standers with one or more subwoofers.
Sokel
Nope,that will give you range,not "bigness".
Horns can give you big sound going only at 45Hz.
There is a reason Meta 1 who everyone describes as big sounding has 4 9" drivers crossed at 350Hz (apart for the pattern they want to achieve).
Talisman
Talisman
Milano Italy
Digby
Another unusual suggestion, maybe you could DIY something to your liking with a 10"/12" bass driver + horn (+mid?). A decent DIY floorstander with a 10" or 12" bass driver will sound BIG and probably have much more extension than a PA speaker - because you don't need the same SPL as PA, the enclosure volume is much larger and the port can be tuned lower.
This is something I've considered, but as I don't have the expertise is off the table for the time being.
Talisman
Talisman
Milano Italy
The branding seems interesting, but as I said I'm only evaluating speakers with at least 8inch woofers, to have that big, punchy feel.
At the moment I find the Dali Obern 9s that someone had recommended above very interesting, they would be close to 2000 but they seem to reflect my tastes. muscular, also aesthetically, with double 9 woofer and 7 midrange.
I'm a little over budget but I have to figure out if it's worth it
Talisman
Talisman
Milano Italy
It would be nice and interesting, but I'm not in the least able to create something like this, I don't have any kind of required competence
rolloj
If you are partial to French speakers, the CHORA line may be of interest to you. FOCAL produces some wonderful speakers.
Mart68
England
I had already read it in a previous suggestion, but also from the graph itself, it seems that the bass response decreases very quickly already from 80hz downwards, and as I specified, I do not intend to integrate subwoofers for the moment.
That's quasi-anechoic though - In room you will get useful response down to 40Hz or so, I'd be very surprised if you can do better that that for your budget (and still have a speaker that measures as well across the whole FR). If you do let me know I'll be interested in whatever speaker it is.
