My Beef with DeaDBeeF (Linux) - Batch Resampling is Incomplete
attoutekina
On Linux DeaDBeeF there is the handy function of transcoding your files to a different format. It can dither 24bit flac files to 16bit, however, I cannot figure out how to change the sample rate. This means I start with a 24/96 file and end up with a 16/96 file. The file size is about half, which is appreciated, but I would like to be able to change the sample rate as well.
Is there any reason why DDBF wouldn't include a dithering function for sample rates as well?
Are there any downsides to doing the reduction using two separate programs (one for bit-rate one for sample-rate)?
Is there another program I can use to easily accomplish my goal?
Is there some issue with having a file in 16/96 format (besides size)? I have read things on here about how in certain cases higher than necessary sample rates can negatively affect sound quality.
Blumlein 88
Use Sound Converter. Look into the preferences and you can choose format and sample rate. You get to choose bit depth for .wav and some other formats. Not FLAC however. Oh and don't confuse it with Sound Konverter. They aren't the same software.
You also can do any combo you want in Audacity. I don't think it does batch converting or at least not simply.
You want to go into Preferences and pick your dither (triangular should be fine).
So in Audacity you open your file, it will remember dither if you have it set. You change the project rate to what you want the new rate to be. When you export it choose the file format and then with most you get to pick bit depth and export it. It exports at the new sample rate and your chosen bit depth.
A
attoutekina
Thank you so much! Sound Converter did the sample rate conversion in batch format - in FLAC :D.
My ffmpeg skills are not so good but that tutorial might be useful in the future, thanks.
monkeyboy
do you need to change the file, can't you just re-sample in pulseaudio?
A
attoutekina
I'm good now. I can use DDBF to downsize the bit depth and Sound Converter to do the sample rate. As with many things on Linux, "where there's a will there is a way" ;)
gavagai
France
Assuming that all tracks are in a folder and you are in a console in that folder :
for x in ./*.flac do ffmpeg -i ./"$x" -c:v copy -af aresample=resampler=soxr:precision=28:out_sample_fmt=s16:out_sample_rate=48000 ./convert/"$x" done
Converts all tracks in 16bits / 48Khz.
Covert arts are preserved.
The resampling quality if the highest possible.
ffmpeg dithers by default.
All the converted tracks will be in ./convert.
danadam
ffmpeg -i ./"$x" -c:v copy -af aresample=resampler=soxr:precision=28:eek:ut_sample_fmt=s16:eek:ut_sample_rate=48000 ./convert/"$x"
I always preferred sox, much simpler:
Code:
sox "$x" -b16 "./convert/$x" rate 48k
Um... mine doesn't (version 4.4.2-1+b3). Below -90 dBFS 1 kHz, in order:
  • original, generated at 24 bit, 96 kHz
  • sox
  • ffmpeg with dither (command like above with additional dither_method=triangular)
  • ffmpeg default (command like above)
gavagai
France
Code:
  • sox
Great post ! Thanks ! So ffmpeg sox dithers by default.
The command line is must simpler indeed. But sox doesn't preserve album art.
theREALdotnet
BeerBear
The resampling that Reaper does is not really good. I wouldn't say it will sound terrible, but it is at best mediocre versus Sox or similar.
Reaper has a few different resampling modes, including r8brain free now, which is very good. (It was added some months ago, so maybe you didn't see it.)
raif71
This thread sounds like BADF00D :D. I remember working with cryptography simulating with verilog/vhdl...these are the kind of testvectors to give so that it is easier to read back to test whether encryption/decryption were done property... DEADBEEF, FEEDCAFE and the various permutation of the hex characters
