ozzy9832001
- Joined
- Feb 19, 2023
- Messages
- 405
- Likes
- 258
Are you sure the fans aren't spliced in somewhere? Did you do the electrical work or an electrician?I know this is an older thread but I am having the same issue but worse. My audio is on a completely separate 20 amp circuit from everything else but when I turn on any one of several ceiling fans in the same or adjoining rooms the amp actually trips the safety. All the electronics are going through a monster AVS 2000 and HTS2600 so they should be completely filtered from any spikes and wiring interference. If the fan is running already it doesnt affect it, only switching it off and on. Any thoughts or fixes?
If they are truly on separate circuits then the only real possibility is a wiring issue back at the panel...
