- Joined
- Mar 23, 2021
- Messages
- 31
- Likes
- 39
- Sibelius: Very nice sound when you find the ideal placement.
- Buchardt S400: Gave them away.
- Klipsh RP 600 M: Nice to start. Gave them to my son.
- Sopra 3: Detailed. Analytical. Awesome.
- Klipsch Cornwall 4: Great sound, terrible looks and cheaply put together. The veneer started coming off in 2 months. Gave them away to a friend, he had them covered with triplay and likes them a lot.
- Pure audio Project:
- Classic 15. Good sound in a large high ceiling room. Spotty build quality. Would Not buy again.
- Horn Quintet 15. Hulking, immense. Would not buy again.
- Hegel 390. Great. Would buy again. (Don't use a TP Link wifi extender when updating software, the amp will freeze. connect directly to the router).
- PS Audio BHK-300 mono blocks, Preamp, Power Conditioner and Cables. Would not buy again. PS Cables are expensive, useless, heavy, unyielding and difficult. Read Amir's review on Power conditioner and Cables.
- Denafrips Terminator Plus. Would not buy again. Very small indicator lights, Complicated to operate, No remote. When Hooked it in a loop with the Hegel it made no difference. Hegel´s DAC sounds exactly the same. Would not buy again.
- Rel 7sx subs (2). Would buy again.Improve sound on all speakers.
- Topping Dac. Sounds good. Looks good. Can't hear the difference between it and the terminator. Costs 1/8 as much. Bought it on the recommendation from Amir. Thank You!
- Rel 812 subs. Good sound. Very Bad customer service.
I bought a lot of equipment based on reviews and you-tube recommendations. it is really a bad thing that reviewers find almost everything great. They really harm the small guy, should be ashamed of themselves.
I got rid of the Buchardts, PS audio BHK 300s, Audio Power Conditioner and cables.
