My new music server - what format please (Mac to PC)??
Saffy
Miami
Hi , have Mac music server and want to transfer all to new external HD - for exclusive use with my Pro-ject S2 Ultra Streamer.
What format should I use exFAT, FAT32 , or other? I'm a PC guy so will be adding future music files that way. I have 50,000+ tracks going into 2TB HD
Thank you
mansr
Hampshire
If no files are larger than 4GB and the disk isn't larger than whatever the FAT32 maximum is, that's the most compatible option.
Saffy
Saffy
Miami
Thanks, I have 50,000+ tracks going into 2TB HD..
DuxServit
ExFAT isn't as well supported across various operating systems.
The OP just needs MacOS and Windows (Win7 & 10), so ExFat should be just fine. I have it on my 5TB portable HDD/usb.
samsa
It's supported since Sunday. I doubt the streamer is running the new kernel, though.
Indeed. Can the OP update the kernel on his streamer to the Linux 5.4 kernel?
There are userland solutions for supporting exFAT on Linux, but kernel support would be best.
mansr
Hampshire
It's only properly supported with the just-released 5.7 kernel. 5.4 has a "staging" exFAT driver, which means it's really only there for developers to work on. Regardless, I would advise against messing with the kernel on that streamer. It likely has some customisations not in the official release, and losing these will break something, possibly make the device unusable.
Promit
I haven't tested in a while but Linux should support exFAT just fine via a FUSE driver. Yes it's being merged into the kernel, but you don't need the kernel level support. I'll also mention that the Paragon NTFS driver for Mac OSX has worked great for me for years, though it does cost a couple bucks.
mansr
Hampshire
There are also ext4 drivers for Windows, if we're to explore all the options.
Saffy
Saffy
Miami
I'm a little confused. Will the Pro-ject E-2 Ultra stream from a HD formated to exFat?
Thanks
Beershaun
Saffy
Saffy
Miami
Thanks, great link. So does the Pro-ject streamer run on Linux?
linuxfan
Saffy, consider a full NAS box instead of an external hard drive - that's usually the preferred option of experienced music server users.
- a NAS is readily accessible to all computer devices connected to the same router, no plugging/unplugging as required by external hard drives.
- the file system used on the NAS (usually EXT4) is largely irrelevant, since the NAS is accessed via a network file system, usually CIFS/SMB.
Which NAS? I like Synology, but also consider QNAP, Buffalo, Western Digital.
ichonderoga
Pretty sure the S2 runs a modified/re-skinned version of Volumio (Linux).
ps fat32 ;-)
Saffy
Saffy
Miami
Yes thanks, it does run on Volumio (Linux), so my preference is NTFS. As exFat is susceptible to power outages, and FAT32 has file size limitations. Problem is my older Mac has no provision to format a HD in NTFS..
