NAD C340
rankfur
Hi i own a NAD C340 I think it’s great I have it linked to my tv for audio the only downside is I don’t have a remote I know this isn’t a major issue but getting up and down to change the volume for things like adverts can get a little annoying, I’d just like to know if it’s possible to buy a remote control that would work with this amp or if it’s just something that can’t be done? I’ve done the whole google search but only comes up with remotes for the c320 and c350. Thanks
staticV3
The NAD C340 does have IR Remote functionality, so it's just a matter of finding a compatible remote:
I found this listing of a used C340 with pictures of the compatible remote: https://www.usaudiomart.com/details/649579989-nad-c340-stereo-integrated-amplifier-wremote-excellent
It's the NAD 450 Remote. You should be able to find one on eBay or similar. Here's one: https://www.ebay.com/itm/314569858791
I also found replacement remotes that are a lot cheaper, but should work just as well:
https://www.remote-control-world.eu...%C3%A9l%C3%A9commande-de-remplacement-p-10120
https://www.remote-control-world.eu/nad-c-12_446/nad-sr-450-remote-control-replacement-p-4751
MaxwellsEq
You are such a helpful person! How do you find the time to do all the research you do to help people?
staticV3
It's nice to be appreciated. Thanks a bunch!
I think I'm just really efficient at googling stuff by now :D
SMc
I like the assymetric top line. Mine wore out ages ago but since the preamp section went south too I don't need it!
The amp section works great with my JBL A170s.
