NAD C658 Streaming DAC Review
This is a review and detailed measurements of the NAD C658 streamer and DAC. It also acts as a preamplifier with Phono and line in. A cool feature is inclusion of Dirac Room EQ and balanced out and you get a killer feature set. For that, you need to pay though to the tune of US $1,650. The owner purchased a factory refurbished which I see going for US $1,300.
The overall design looks quite nice with a larger and informative display:
Here is the back panel:
NAD C658 streaming preamplifier DAC Back Panel Connectors Inputs Audio Review.jpg
The only feature missing that should be there is the unit acting as a USB DAC. It has a USB connector but that is it acting as a host, playing content from external storage.
Since there is no USB input, I started my testing with Coax S/PDIF. To my surprise, the frequency counter on Audio Precision was jumping all over the place as was the waveform. This indicate lack of lock on the incoming clock which could either be a design flaw or something broken in this unit.
I then switched to Toslink optical with the same result. Wanting to make sure my analyzer had not failed, I powered another DAC and it worked perfectly there.
Without these inputs working, the only digital path I had was streaming using Roon which worked fine. Roon complains that it is not certified but worked anyway.
Streaming DAC Audio Measurements
Here is our usual dashboard:
Even though performance bests the specification at 0.005% distortion, this is well below acceptable in a high priced device like this:
The only other test I can run this way is jitter:
That spray of spikes should not be there. Fortunately it is at -130 dB so not an audible concern.
Shame to see quality control or design issues in a brand like NAD. Even if the digital inputs were not broken, the performance of the DAC fails to even match a half decent $9 phone dongle. So despite great feature set, NAD needs to go back to the drawing board and clean up its implementation.
Needless to say I can't recommend the NAD C658.
The panthers are threatening "social distancing" if I don't give them a raise. Can't let that happen as I will be out of business. So please donate as much you can using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
sashi2
oh, that's unfortunate (though I admit I don't understand everything in your review). I was suspicious of too many sources of refurbished NAD units popping up in a Google search thinking it could be an indication of quality issues with too many of them. I've read another review that said the unit didn't start performing well until room correction was applied to it. Do you think it's possible they don't calibrate them much relying on calibration by the room correction software? Even if this is the case, it sounds like a weird decision still.
If I understand you right, no digital inputs work, that the #1 issue. Secondly, Sinad readings are sub par, especially considering the unit's list price. Do you think the poor Sinad readings are also indication of the defective unit?
Reactions: wje
No, the problem I found has nothing to do with Dirac. I should note that I had it update itself and made no difference.
The SINAD is actually slightly better than what they specify so that is not an indication of a broken unit.
gvl
SoCal
If not for performance, at least the feature set is decent and can acquit it?
Dj7675
I was very close to purchasing this unit several times. After seeing the disappointing bench test results of the NAD T758 V3 I sent in, I just couldn’t trust NAD without seeing it measured first. It has a great feature list, a shame it doestn’t measure better, but not surprising unfortunately. However it does have a ton of functionality which could be quite useful in the right setup. Really strange the digital inputs wouldn’t work. Thanks to Amir for the measurements and to the owner that sent it in.
Veri
No 32-tonetest signal jitter measurement?
TabCam
Thanks, should have made that conclusion myself but did not have my morning coffee yet and a flu is not helping either :facepalm:
Mnyb
Sweden, Västerås
It still missing a feature , very close to be the kind of product i want .
DAC/Preamp with room correction + EQ and subwofer output , why no sub out ?
Sorry it actually has sub out :) this makes things interesting . Sorry for being blind and seeing the picture correctly .
Sinad is mediocre but it has sub out and room correction thus it will sound better than any and all DAC's without sub out and room correction .
So how bad should the SINAD be before the advantage of room correction and subwoofers is overun :D 80 - dB 70- dB 60 -dB probably when noise gets iritating at listening position ?
MZKM
Land O’ Lakes, FL
This too was at one point on my short list of "all in one streamers", but alas maybe the NAD Master M33 will do better for $5,000?
https://nadelectronics.com/nad-mast...purifis-ultra-quiet-amplification-technology/
https://www.stereophile.com/content...tdigital-da-integrated-amplifier-measurements
Besides what’s happening >10kHz it’s pretty good.
However, 8ohm wattage and 4ohm wattage are identical, meaning you will get 3dB less power when your speaker dips to 4ohm. You will need to use the room correction to fix this.
Hephaestus
Rapture
Thanks for the review.
I have this unit in our living room setup and it is plagued by horrendous software. Subwoofer outputs have level issues, plopping sounds when changing tracks, some sort of occasional phantom noise...
Networking issues...
See lengthy complaint thread in AVS forum....
Stay away from this unit - headless panther tells it all.
