Navigation in threads on mobile devices
  • Thread starter Deleted member 48726
  • Start date
D
Guest
Hi
When on the forum on a phone and entering a multiple page thread, you currently have to scroll to the buttom to access the different pages in the thread.
Is it possible to make this page selection appear on top of the thread instead?
staticV3
At least on a tablet, the nav bar should appear at both ends, like it does here on a Tab S5e:
antcollinet
UK/Cheshire
Same on an iPad, but not on an iPhone. I suspect the top page navigator vanishes when the screen gets small enough to make the menu fold up into the three bar drop down top left...
antcollinet
UK/Cheshire
On an iphone it looks like this when scrolled down to the bottom of the page. You can tap the page numbers in the middle to go to any page.
I agree that it would be very useful to have that navigation at the top of the page if it were possible to do.
antcollinet
UK/Cheshire
So just found this as a workaround. (at least in safari). This tip shows how to set up a shortcut which will scroll to the bottom of any page...
EDIT : This seems to be browser agnostic. Just tried it on a desktop google based browser (Brave) and it worked there also.
AdamG
Enjoy the Music your way…
Moderator
Reality
D
Guest
Yeah, I suppose it does work and good detective work!
But finding the bookmark and selecting it is a bit cumbersome in relation to having the selections at the top. And this is only on my iPhone I find that scrolling to the bottom is something I find myself doing quite a lot to get to the page selection section.
Most times when I enter a thread (on iPhone) it doesn't show the first page and to get to the front page I need to scroll down to the end and select the "<<" button to get to page 1 where I want to start reading.
It looks like this (TOP VIEW)-->
AIL4fc82spI11gXyWqFAgPOWo-z-iKIz7t9gX8IK8f_kRbabEi_3m3v3262h5dzG4Xg0MzM21ayl24z5V5eQyfKPAiTiNl-oi1rHGUmxs_R0ctmisSLTZPjZw3tS-oo-WfYD3HuWRcnlhmpdLJ7n5PbY93KurY4JuWocijgQAoiK1QMCEyE7-AHn3_VLV9aTvnInv4YFnVoXMQ6_Gwt9qD0gX9SJ4HHQzXyoXIvYMizeoiAxpIlazh9dcXyKajW7Oe7K9wAH-UqM5_y2oYigWa7g3EG_k543CkJDYmy3eT_7XVB4FCcB-7kEuO5LtcV72OBijruMXw7fJOc3UOnRhJCw_SU0Iild_I1SX80Oucv0Tnd2tvKD4Y9m-1ghm22E-bYWZgzJTmMeAJneu1yllknMJQgR1jMOF-BwrlgOV7FB3sm2zvH7P5SkgjkSFXxMPRyY4OcdXwX819YJXoobYlCNH7M8tP9Kl9K7D2IcYSP0HHKxRW5XDHGPAf9LDsUCQp3-HXIildmIaQN_Fe22SCnvnlBWt0Ato5gtnig5GRXlgjKhGc_Nnmkw0iR-CLgwN2Nj_L4gr2-b1n13kX-cLPiuTo5Ut714U8tzZnRgziPQxX9e6qe5SRzphxjBsw8tk0SwmD1te1Siuv0PELjAv2SGdPv5qrNSAOyjuWTWK4mby5kAD-ZMfJ1IGXvk8JOggU_GFcUz1bkYUCUC_ztXt8hcyRBgfEi-EVXVtZ3GmgbNVczbWh-QbHVpgP9xd-8Dd5WpprOQjU8w5iQLTj1n0mvPV6K2NroYG4HzCLgNpdFwBm5FlEaNkk3Ea72ZsophYjhlaJwXcOtg7rBnU1ABu1fuy4sToDNveH9BA2uR3oU4ZGUMvhMCduzQgxilm-8rWn0zR163ZOZ0MReQ83HcmUoOm9wFMOs=w458-h937-s-no
And this (BOTTOM VIEW)-->
AIL4fc_-lG3QoatvRyxeXVM1aHp09qBlrmMz-ZpQFsCmSFIMHRX0hpHEXVcJKSQwYQ4Cmzg33or3baJ5vALmtNYozrSU5fXk51SXdMlu87KO9viIaF9LdSCzQkbwU7qT0sSAgbsM24DOfLfX8fZpIJLrKwNhVN1zWbUxquOHHmu2An8Q_dqV16xn8RlZ1CTxCE9GnApwu46MfCZ4Hh0udTrh6lne9y-dVGbzJam2jp3yGqLLc19iSOZVSU5mcD8Z6pWpPx6wlr6AAtRsaJcWsYndO23J0imPpw46cXffTkXkU_MqS8RQjjCjulkH2aw_8X1QCJGtx7GJI1Np18XwJDzXUopVHKocEYiKZmz8dkmNVIui85QlRYVz9e8N_2FshweISYwvj0eMqOO3X-7186BDk7dER0IPq0lNvFr-sALgz5gbJ7TN4y2ujyTdjJP_6RdPIjKvYRANF9-fLxmF0-Dm4nwP0z77jzXxM12E8LErMXbSVT88bh7B2A49vYZg16uc_2Gs2SDwkB083TsiIUiHeg2fCkpHHK8VKVaPaZHkxLZqKbc81LwM45IWajpDpo8nt-Mg2oUqR_y2NxjmNEFMmecwpZ9R3HsprpoIXEDAI7isqktbxbwJFAKc1cLyYKEEPMAgWaOrfnHatdzE0Upsmongz17fo4UW5qp0VL4alRduecZbnsToAaqgJTwFCMT42_1QJ5RDUFprmOeKyBCbvT-8kc-hJnLeIsA_8m6i1EN3aNLUa_265g7MrV-VMRfXaQnu8_hRQwxLqzsb9OS_sCUmaP63e81njhRInxrdVH5jT0DiMrX06MMu0D-_Z812Ne-654heRtJEaIvMxDK08E9_0tCZhXCI9Wna3em331EUgNhi1kB9iXFq738beCqD5BSZeJ5Oxx2_Wi_-Pi1nWkli78o=w461-h937-s-no
vicenzo_del_paris
Brittany, France
Hi
I have the same issue on android :(
Daily checking/reading ASR on my phone and I share the same frustration :)
threni
/dev/null
Yep, same here (Chrome on a Pixel 6a). I assume the intention is "continue reading from the page you previously reached - don't jump around the thread".
antcollinet
UK/Cheshire
I've put it at the top of my bookmarks - it is two taps to execute.
D
Guest
And the scrolling down to bottom takes 2 sec. as well. It's just not that convenient.
It's a workaround. Not a user friendly solution.
antcollinet
UK/Cheshire
Instant for me: Probably device/browser specific. But yes, I did introduce the idea as a workaround (I specifically used that word). We don't have the ideal solution at the moment.
D
Guest
No belittling of your suggestion at all. It is great of you to chime in so quickly with a workaround! :) -It's just, as you say, not ideal.
May I ask what you mean by "we" don't have the ideal solution?
antcollinet
UK/Cheshire
We: ASR :)
Chester
How strange, I was about to post this exact request yesterday but got distracted.
I think it can be done, as other forums I visit that appear to use the same platform have it at the top as well as the bottom.
D
Guest
Audiokarma has the same issue. Or "feature" if you will.
D
Guest
Headfi uses Xenforo and has page navigation at the top on mobile. Not sure which versions each forum uses though.
Okay, interesting. So it seems like it's a matter of setup?
Versions can be seen at the very bottom. This is ASR-->
And this is Audiokarma-->
And Head-Fi-->
