Need AMP in which will be DAC + preamp for Wharfedale Diamond 12.1
Krounder
Need AMP with USB input in which will be DAC + preamp for Wharfedale Diamond 12.1. Price range - 1000 eur(or 1500 if you have variant much better). What I need from it: clean sound, not some shit with "warmer" , "it is very good with female vocal". Need neutral sound, with good measurments. Be glad if you attach audio measurments to your variant.(Now Im thinking about rotel a12) And btw Wharfedale Diamond 12.1 are good for neutral sound or I can get better speakers in that price range for that? (For example PreSonus Eris E8 XT will be better than Wharfedale Diamond 12.1 or not?)
MrOtto
Topping PA5 + Topping E50 https://www.tpdz.net/productinfo/737898.html
K
Krounder
MrOtto
Why? These two items do what you ask for. USB input + AMP/Preamp. This is the ultimate neutral/clarity sound option within your budget and both have measurements and review at ASR.
MrOtto
MrOtto
You get 3x digital input + 1x analog input (when the other is used by the E50 DAC)
kokakolia
Audiolab 6000A is a no-brainer.
If you want the most neutral sound then spend more and get the Roksan Attessa.
K
Krounder
Can I enable both amp + pream for pa 5? Or I need to buy pre90?
MrOtto
No preamp needed, you can use the built in volume control of PA5. You can also regulate the volume by remote with the E50.
You then have 1x analog, and 3x digital inputs free to use
You also have balanced analog outputs, inputs. What kind of price do you have to pay to get that in an integrated amp?
Buying these two seperate items, you know you have almost the best there is with measurements to show it. Buying an integrated amp, you rarely know what you get kn the amp and DAC departement
Also you are free to upgrade either if you like.
