HarmonicTHD
- Joined
- Mar 18, 2022
- Messages
- 3,326
- Likes
- 4,836
Or apply EQ….I am afraid that if you like your B&Ws you need to train your ear to the KEF sound. BTW, from the picture your stands seems so high (3 feet, maybe?), why?
No eq correction.You don’t have any sort EQ / room correction profile on created using the B&Ws, right?
Sorry to say it - but I read that and immediatly thought it sounded sketchy as hell.The previous owner used the speakers with high -end McIntosh gear. Unfortunately before I picked up the speakers he had sold the amp, so couldn't test.
Your crossover into the tweeter is at 2.9KHz. Try an online tone generator at 2KHz, and at 5Khz (Turn your volume way down, set the 2KHz, then turn the volume up until it is clearly audible but not too loud, then try the 5Khz)When I unLink the knobs and (set the woofers to off) I can still hear sound from the middle driver...is the above method best to test a blown tweeter?
Just did some (subjective) initial tests. At same volume level, 5k frequency is louder on 705s2 than the R11s. Is that to be expected? I have a Radioshack spl microphone so will do a more scientific, objective test tomorrow.Your crossover into the tweeter is at 2.9KHz. Try an online tone generator at 2KHz, and at 5Khz (Turn your volume way down, set the 2KHz, then turn the volume up until it is clearly audible but not too loud, then try the 5Khz)
If the tweeters are blown you'll be getting very little sound at 5Khz.
Try setting balance fully left and fully right to test each speaker in turn.
You might need to try some freqencies on either side of 5Khz (I'm deaf at 6KHz due to tinnitus). Also worth trying this with your other speakers first to hear what the two tones should sound like. Your ears are less sensitive at the higher frequency so it'll sound naturally less loud even at the same level.
Online tone generator
Online Tone Generator - generate pure tones of any frequency
www.szynalski.com
EDIT : To get a little more objective, get an SPL meter on your phone. Measure the output of the speaker with this at the two frequences. Repeat with your other speakers. (Keep the speaker to phone distance constant throughout)
Your speakers may have different sensitivity. You need to check the difference in level on one speaker, compared with the difference on the other.Just did some (subjective) initial tests. At same volume level, 5k frequency is louder on 705s2 than the R11s. Is that to be expected? I have a Radioshack spl microphone so will do a more scientific, objective test tomorrow.
I think the fact that you hear anything at all at 5kHz likely means that the tweeter isn't blown.Just did some (subjective) initial tests. At same volume level, 5k frequency is louder on 705s2 than the R11s. Is that to be expected? I have a Radioshack spl microphone so will do a more scientific, objective test tomorrow.
Just to explain this a bit more in case it isn't clear...Your speakers may have different sensitivity. You need to check the difference in level on one speaker, compared with the difference on the other.
I get a great sense of height as well. It’s a 3d like bubble. Really noticeable with HT content as the center channel gets in on it too. I’ve had or tried 4 different speakers for the center and none of them came close to being able to place the voices on the screen like the 650c. I can sit on the floor in front of the TV at around 2’ from the speaker and the voices still appear to come from the screen. It’s an 82” screen.I said height wise as it is a multi driver array. Horizontally it's great, which is what you're saying, so we are both saying exactly the same thing.
I have a pair of ML prodigy, 702s2, kef wireless 2...and used to their sounds and really like them.
After bringing R11s home, I hooked them up to emotiva xpa1 monoblocks (600wpc @8) - bi-wired. Turned the Link knob all the way counterclockwise. Ready for a listen, and I am shocked how subdued the sound is. Like remarkably poor high frequency response, poor volume... forget about soundstage! Volume seems quite low as well.
So wondering if you are aware if these sound like how I am experiencing or I have bad combination or something I am completely unaware of. Please chime in, and thanks in advance.
