Neumann KH 150 Monitor Review
Rate this studio monitor
    Votes: 0 0.0%
    Votes: 3 0.6%
    Votes: 44 8.5%
    Votes: 470 90.9%
DJBonoBobo
any germ
It's strange that they would recommend it with the KH310 but not the KH150 when like you said the limits are the same.
Yes, very strange they talk about the KH150 in a KH150 video. I sense some kind of conspiracy.
The dark wizards of sound magic probably want to keep their secrets....
gino1961
actually they could offer a model in between the 150 and the 310 with a 8 inches woofer
like the Genelec 8050 for instance
LTig
Europe
It seems they don't want to, consistently since some 30+ years (K&H O98, O198, O300D, Neumann KH310 all have an 8" woofer and are 3-ways).
Pearljam5000
Thanks (;
Yeah but correct me if I'm wrong they also never had a 6.5 2-way
thewas
Ok
Anyways i think that if Genelec has all 3 common sizes they should too.
Adam also has a 2-way 8 inch and probably many others too
Genelec had and has also some 10" 2-ways and many more models like coaxials and mains which the much smaller company Neumann doesn't. A large driver is a compromise for the mid band which is the reason why some companies avoid it, even Genelec uses on their flagship 2x5" mid drivers instead of one bigger.
unpluggged
Ok
It doesn't. ADAM's pro monitors are the S series, and the only two-way model is the 7" S2V.
gino1961
A solution could be a 1.5" dome that could work lower in Hz?
There was even a 52 mm dome tweeter from Kef once t52b i think it was
Sokel
Genelec also has a 10" two way,in it's main monitors series.
Can't find it's xover freq though,it does state them in the other mains but not on this (S360A).
Edit:Found the xover freq,1.4Khz(!).
(someone has done some magic here integrating those drivers).
enricoclaudio
Houston, TX - USA
Neumann strongest suits are mics. Comparing Genelec with Neumann regarding studio monitors is like comparing cars offerings from Tesla and Ford, GM or Toyota. Genelec is an exclusive speaker company while Neumann is a multi products company in which mains products are microphones and happens to offers some very good quality studio monitors.
DJBonoBobo
any germ
Neumann ... happens to offers some very good quality studio monitors.
Sorry, but this is misleading. It not just "happens". Georg Neumann GmbH has been part of Sennheiser since 1991. Sennheiser then also acquired Klein und Hummel in 2005 and has since further developed their products under the "Neumann" name. The team and everything was taken over from Klein und Hummel, even the head developer (Markus Wolff) is the same to this day. Hence the "KH" in the Neumann product names.
Klein und Hummel has been making studio equipment from the 1960s. So the Neumann KH products are really looking back to a lot of history and experience with studio monitors.
Here is the K+H O98 from 1982, for example
and it´s successor, the K+H O198
The O110
The O400 from 2002
And it´s successor, the O410
So, you see, Neumann is just developing the Klein und Hummel products further.
Edit: Here is an old catalogue from around 20 years ago with full measurement sets of their whole lineup.
enricoclaudio
Houston, TX - USA
The O110
The O400 from 2002
I’m not miss leading, my point was to clarify that it’s not fair to ask Neumann to have the same offerings as Genelec does. After Sennheiser adquired K&H back in 1991, Genelec still is a much bigger company with much more offerings regarding studio monitors. And still, Neumann strongest suits are microphones, not studio monitors.
gino1961
the 2 ways are designed mainly for near field listening in mind So smaller woofers can keep the distance between the woofer and tweeter sound emission points to a minimum
the 3 ways are more for mid field and they provide more range and SPL
in some cases where the midrange is strong enough like in atc speakers the even bigger main monitors have only bigger woofers but they keep the same mid and high domes
in other cases main monitors uses a couple of cone mids
it's impressive the undistorted SPL that some mid domes can provide in their optimal working range like Neumann of course
