Neumann MT 48
Matias
São Paulo, Brazil
New interface from Neumann after the Sennheiser group acquired Merging Technologies in 2022. Looks like an interesting all in one with DSP for 1850 USD.
Story
Website
VintageFlanker
Paris
Looks gorgeous!
...while not cheap (1995€)
Manufacturer's specs:
DATA & DIAGRAMS
Mic Inputs 1 -2:
Dynamic Range136 dB-A
Equivalent Input Noise (150 Ohm)-128 dBu-A
Input Impedance10 kΩ
Gain Range12…+78 dB in 0.5 dB steps or 0.1 dB (fine)
Pad12 dB/24 dB
Max. Input Level0 /+12/+24 dBu (without Pad/with Pad)
THD + N Preamp + ADC @ 1 kHz, 0 dBFS< -110 dB (0.0003%)
Line Inputs 1-2:
Dynamic Range138.5 dB-A
Gain Range0…+66 dB
Sensitivity+24 dBu…-42 dBu
Max. Input Level+24 dBu
THD + N Preamp + ADC @ 1 kHz, 0 dBFS< -105 dB (0.0006%)
Instrument/Line Inputs 3 - 4:
Dynamic Range135 dB-A
Input Impedance2 MΩ (balanced) / 1 MΩ (unbalanced)
Gain Range0…+66 dB
Sensitivity+18 dBu … -48 dBu
Max. Input Level+18 dBu
THD + N Preamp + ADC @ 1 kHz, 0 dBFS< -112 dB (0.0003%)
Line/Monitor Outputs:
Output Impedance< 70 Ω
THD+N@ 1 kHz, 0 dBFS< -110 dB (0.0003%)
Dynamic Range123 dB-A
Max. Output Level+24 dBu
Headphone Outputs:
Output Impedance0.035 Ω
Dynamic Range122 dB-A (high) / 117 dB (low)
Max. Output Level+16 dBu (high) /+8 dBu (low)
AES67/RavennaStandard RJ-45 Gigabit-Ethernet-Anschluss
Expansion Connectivity"ADAT/S/PDIF optical I/O, MIDI I/O via 1/4” jack, (DIN5 adapter set available from Neumann: Cat. No.700261)"
Computer InterfaceUSB-C, 2.0 High Speed (480 MB/s) or higher
Power Consumption<25 W
sarumbear
Ridiculously good microphone amplifier specs. 68dB SNR at 60dB gain!
Mic Inputs 1 -2:
Pad12 dB/24 dB
Matias
Matias
São Paulo, Brazil
With 4 band PEQ I can already see users requesting more, like RME ADI-2 series hehe.
enricoclaudio
Houston, TX - USA
I was about to make a thread for this new AI :) 136dB Dynamic Range is impressive. I do really want this AI tested by @amirm . My Sweetwater guys tells me it should be in stock by end of the month.
enricoclaudio
Houston, TX - USA
Here is the Sweetwater Hands ON video. The touchscreen UI is really cool.
DJBonoBobo
any germ
With 4 band PEQ I can already see users already requesting more, like RME ADI-2 series hehe.
At least 1 more than RME's TotalMix FX... Did anyone see power-related specs for the headphone-outputs?
enricoclaudio
Houston, TX - USA
I don't see power ratings for the headphone out:
Matias
Matias
São Paulo, Brazil
I guess the +16 dBu are 4.9Vrms according to this.
enricoclaudio
Houston, TX - USA
BTW, the inclusion of AES67 interface makes it very compelling for KH150 AES67 owners.
dshreter
What a beautiful product... which I have no excuse to buy :p
If I were making a wish list for someone focused on desktop listening and not production, it would be really slick if a future version could control the DSP capabilities of their monitors and room correction over the network.
DJBonoBobo
any germ
I don't understand the calculator. Is it possible to calculate a measure in Watts for 300 Ohm and/or 32 Ohm headphones?
DJBonoBobo
any germ
Watts is V^2/R, so if the voltage is 5v, say, the power into 32 ohms will be 780mW, Into 300 ohms, 5V will give 83mW.
S.
Thanks. So, if true, this should be enough for most headphones except the most power-hungry.
Blumlein 88
You aren't really going to get 136 db dynamic range. Interface specs are a bit deceptive about this.
thecheapseats
Los Angeles refugee
as I posted when I first read about it... 78db of mic gain... 136 dyn range... a bit of gpio i/o... AoIP... well ok then...
kemmler3D
San Francisco
Looks awesome if you need a maximum performance 2i4o interface but not sure that 3 bands of PEQ and a decent headphone amp are good enough reasons for listening-only buyers to get this thing at nearly $2K.
sarumbear
Not for listening only but this is not a DAC, hence listening only is not the aim.
thecheapseats
Los Angeles refugee
a production tool - aimed at the UA apollo twin/?quad? market... guessing...
