Nevermind... gonna keep it
Astoneroad
a Cave in the desert
This is a great sub, in perfect condition, I'm the original owner. This has never been driven hard and for all functional and cosmetic purposes is easily a 9/10... without being factory sealed. I've got the factory box (great shape) and everything that came with it originally, feet spikes, etc.
This unit has ARC room correction, as well as app driven settings so you can adjust from your listening position with the proprietary app. This feature saves a lot of set up time and frustration. It can also be used wireless, with an available transmitter (not included). It can also be configured to fire front or down, which gives even more set up flexibility. This model is still available and is $1500 retail.... or you can get it here for $799 w/ free shipping, no tax and free Friends and Family Paypal. Questions?
ML 1100x factory page
Specifications​
Specifications are subject to change without notice
Frequency Response22–200 Hz ±3 dB. Anechoic in LFE mode.
ImpedanceRCA: 8,300 Ohms
Speaker Level: 2,000 Ohms (red to black)
XLR: 28,000 Ohms (pin 2 to 3)
Low Frequency Transducer12” (30.5cm) high-excursion, inverted surround, polypropylene cone in a cast aluminum basket with extended throw driver assembly; sealed non- resonant cabinet design.
Amplifier650 Watts (1,300 peak)
SoftwareSub Control App: iOS and Android
Anthem Room Correction: iOS, Android, and PC
Room CorrectionAnthem Room Correction (ARC)
Controls (Backplate)Level: Min–Max
Setting Control: Local, App
Power Mode: On, Trigger, Auto
Controls (via Bluetooth)Level: -40 to 12dB
Low-Pass Filter (Frequency): 35–120Hz
Low-Pass Filter (Order): Bypass, Third, Fourth
Phase: 0–180° (1° Increments)
Phase (Polarity): Normal, Inverted
Preset Listening Modes: Music, Night, Movie
20–30Hz Level: ±10dB
Anthem Room Correction (ARC): On, Off
Tone Sweep (20–120Hz): On, Off, Pause (Frequency)
Inputs (Audio)Line Level: Left, Right, and LFE
Speaker Level: Left and Right via banana jacks XLR: LFE
Inputs (Audio, Wireless)SWT-X Receiver & Transmitter (sold separately)
Inputs (Other)USB: Micro USB (for ARC/Firmware Update)
Trigger: 3.5mm, 5–24 DC
Power DrawTypical: 100W, Max: 600W, Idle: 15W, Standby: 0.5W
FeetRubber, ETC (Energy Transfer Coupler) Spikes
Weight46 lbs. (20.9 kg)
Dimensions (HxWxD), Front-Firing17.2" x 15" x 16.2"
(43.6 cm x 38cm x 41.1cm)
Dimensions (HxWxD), Down-Firing17.1" x 15 " x 15.6 "
(43.5 cm x 38cm x 39.6 cm)
FinishSatin Black
