used this for several shows over the weekend in my concert recording rig
it was pretty seamless
in addition to the front panel mic inputs, i used an RME quadmic to fill up the 4 channels on the back with mics, and ran a separate 2-channel preamp to the TRS on the front
i was a little panicked when i realized i left my usb A-B cable at home, but after some digging i was able to set sample rate and arm each channel in the menu itself
i initially tried this usb stick in at-home testing. just like the youtube video said it would, the samsung flash buffers and causes a few errors at high bit rate.
it that turned out to be inferior to either of these, which work with zero errors when testing with maximum bitrate (16ch at 192K). are the few erors on the first drive audible?dunno but i do know that zero errors are better than one or more!
i actually mixed and matched them and used the 128GB samsung card in the rocketek reader
this is also a very handy cable that ive used to test my Ugreen M2 enclosure with a sata stick inside. nice to bring it to the front of the gear bag instead of pulling it all out to get to the card reader at the end of a night
some uploads, i ran a variety of mics.
this is the same show from three different stereo mic pairs
Source: Neumann KK14 > JF Actives > DPA MMA-6000 > RME Fireface UCX II @ 24/96 > Normalize only, no other processing or EQ > FLAC level 8Set One...
archive.org
Source: Schoeps MK41V > CMC1KV > RME Quadmic > RME Fireface UCX II @ 24/96 > Normalize only, no other processing or EQ > FLAC level 8Set One...
archive.org
Source: DPA 4018VL > MMP-ES > RME Quadmic > RME Fireface UCX II @ 24/96 > Normalize only, no other processing or EQ > FLAC level 8Set One...
archive.org
