- Joined
- Jan 15, 2020
- Messages
- 6,905
- Likes
- 16,967
In then end you up though with a similar dynamic range and max SPL whether you boost with up to 10dB or pull down the target by 5dB and boost with up to 5dB, what only matters is how much you will fill the lowest regions like dips.Despite many advocating only using DIRAC below 300-500Hz, such generalisations do not consider the state of the bottom end in one's room. For example if I was to EQ with DIRAC and cut as required to boost bass response while maintaining reasonable distortion I would end up with a 10dB rise at 300 or 500Hz and ridiculous tonality. Instead it's necesary to cut the whole range and only boost the worst bass response by 5dB locally.
Anyway filling room related dips should be always be done with upmost care as a nicely filled FR oftens sounds rather muddy, best is to try to minimise dips by placement variation and room treatment.
Here is also a relatively new article about how to anchor the low region correction in DIRAC:
https://www.soundstageaccess.com/in...-could-breathe-new-life-into-your-av-receiver
