New JBL 4349 Speakers
Juhazi
Finland
Hope they rewrite the manual I read it , it was mostly marketing speak too and no good specs.
The manual even included a long burn in period :facepalm:
That said looking forward to measurements on this one.
Perhaps it was April fools, or someone at marketing dept. got bored working from home...
- a compact, high-performance bookshelf loudspeaker
- delivers music with authority and accuracy not possible with traditional loudspeaker designs.
- Pure-pulp cone woofer for powerful dynamics and incredibly accurate sound reproduction
- an advanced crossover network design that features air-core inductors, cast wire-wound resistors and low-ESR metallized film capacitors in a multi-cap configuration
- 3-inch (75mm) long-throw voice coil in conjunction with dual opposing spider dampers guarantee maximum output with significantly reduced distortion
Anyway, I believe that this is a very good loudspeaker! Dual diaphragm compression driver with M2 horn is pure work of art. Box is classic and solid. Bass most likely has rather high tuning to get maximal spl. Subwoofer(s) are needed for full range hifi at home.
watchnerd
Seattle Area, USA
And it has instructions for bi-wire!
Mnyb
Sweden, Västerås
Yes I too really thinks this is a good one , and i'm all for a rather high bass tuning , many two ways have an almost unrealistically low tuning partnered with it's drawbacks as low effieciency etc (clearly sub optimised ,for example why 35Hz with a 6.5" driver give me 45hz and 3dB more eficinecy and spl please). So sub may be needed if your into to that really low bass.
Mnyb
Sweden, Västerås
yea and claims that it sounds better ! too .
I must aplaud Dynaudio for simly not having biwire terminals on thier speakers or have they given up and include them too nowadays ?
Off topic , Do samsung/harman own any speaker cable company if soo moar triwire speakers :p( they exist sadly )
peanuts
this is the EQ profile of the m2 horn, i wonder how they do it passive
ROOSKIE
Minneapolis
Still single wire to my knowledge. My 2018 model Contour 20s are single wire.
Well, some folks will want to bi-amp. So the added terminals make that possible.
They also make it easy to independently measure the tweeter and woofer.
This alone makes them desirable in my book.
Bi-wire = sure it is market driven but I don't see why not to do it if the terminals are there. If you are on this site your wire was very inexpensive. Just run two for extra maybey's and think nothing of it.
watchnerd
Seattle Area, USA
I'm a bit confused....my comment was in response to someone asking about Dynaudio, which are all single wire.
watchnerd
Seattle Area, USA
JBL HDI 3800 = $5000
JBL 4349 = $7500
The horn appears to be the same and the 4349 data sheet says it's an HDI horn:
" Patented High-Definition Imaging (HDITM) horn, precision-molded in Sonoglass"
Bass and sensitivity specs are darn close (37 Hz -6 dB vs 32 Hz -6 dB, 92 dB vs 91 db).
And the HDI 3800 doesn't need a stand.
So what does one get for that extra $2500?
I'm not familiar enough with JBL compression drivers to know if the one in the 4349 is $2500 better, or just different.
Or is it just $2500 to pay for the retro looks?
aac
You'll get better directivity control (if crossover is ok on these).
aac
Why?
And that 12" woofer crossed over at 1500 to 1700 Hz (whichever) looks suspiciously close to beaming.
Wider baffle and larger cone.
The wider you get the lower you can control directivity, unless you use some tricks with special acoustic boxes like cardioid vents.
It's from another manufacturer but it's easy to demonstrate like this. The larger the woofer and baffle the lower directivity control goes, speaker becomes an omniderictional lower in frequency..
Genelec 8330, 8350, S360, 1236
D2415K compression driver is significantly more expensive than 2410H and is larger.
watchnerd
Seattle Area, USA
Where is that breakpoint?
Between sub crossovers and Schroeder impact, it seems like it wouldn't matter much if it's much below a few hundred Hz.
richard12511
JBL 4349 = $7500
The HDI looks WAY better(IMO), though I know some folks like that retro look. I guess I’m too young to really appreciate it.
watchnerd
Seattle Area, USA
Now I'm curious how young that is.
Hipster Millenials into retro hi fi aren't that old.... :)
But Gen Y are more into headphones...
