New member from Gouda
LTig
Europe
I don't think this is the the best way to welcome a new member to the forum. I think most members join with with subjective views, with the hope that they will become more objective based on the evidence provided here. If someone tries to ram their subjective views down your throat, thats another matter, but Wenslauw doesn't come across that way.
Usually newcomers lurk around for some time before they join so they know what to expect;). I must have missed though that this is not the case here. As non native english speaker I'm not aware that "Uh huh" is offensive, so sorry if it came over as such.
Wenslauw
Wenslauw
Call me old fashioned but I'm not a fan of putting the electronics, amp and electronic crossover in the speaker cabinet.
Someone else mentioned active speakers. I have thought about it as I read in several reviews where it said that it often works better than passive speakers, but I like the possibility of upgrading components.
Doodski
Yes, for sure and you can get a better amplifer or at the least control what you get.
LTig
Europe
Most floor standers are quite big. The footprint might be just as big as a bookshelf on a stand, but they will look rather massive in our living room. At this point in time I'm thinking of putting them where the current (small) speakers are, on both sides of the tv. As the room is only a little over 9 feet wide at the point where they'll be, I think I'd never get my wife to agree with big floor standers.
Sounds like the perfect application for a small Genelec 3-way with coax driver.
Wenslauw
Wenslauw
Don't worry, I wasn't in any way offended. I'm just curious what you meant.
I'm just very curious and quite obsessed with finding what would be best for me. I haven't heard much yet, so I'm still quite a blank slate. Which is also a bit uncomfortable as there is so much equipment to listen to and so much to learn.
Doodski
Have you seen anything in a hot running pure class A with near linear power supply? Or have you been looking at class D
LTig
Europe
That was me. I switched to active speakers 15 years ago, and in the mean time all our systems use active speakers (Klein&Hummel - now Neumann, Genelec, JBL). The relation of SQ to price is unbeatable, as is the relation of low bass to size. Dynamics is very good even for very small ones like Genelec 8020.
From a technical point of view therefore it makes no sense to use passive speakers, a fact that has been accepted by the pros for many years now. In most recording and mastering studios you will find only active speakers.
Wenslauw
Wenslauw
I think I've mostly been hearing class AB. The Primare was class D. The Naim had a class A pre amp, but I don't know what the rest of the amp is. It's not always easy to find those details about an amp.
Doodski
Something with good linearity as the speakers impedance changes is best. If they have good linearity specs they will tell you. Sometimes a stealthy 50 or 75 watts of pure class A can be good. Higher being better of course but there is a budget.
Wenslauw
Wenslauw
So are they trying to take back the Gouda name like the Feta, Champagne and Prosecco? I like Gouda cheese. :)
Welcome.
Thank you. I think it's a protected name as of 2010. I read somewhere it would take a lot of money to make sure it's not produced outside the Netherlands. I don't know the details. I never eat the stuff myself. ;)
Wenslauw
Wenslauw
Don't class A amplifiers run really hot? I also haven't come across any. Seems like most (popular) brands stick to AB these days.
Doodski
Yeah sometimes. It's more of a warmth than a hot :) I don't recommend it for tropical rooms w/o AC but yeah it can be good. It sounds great and if somewhat linear as suggested it should be fantastic. It's a choice, lower wattage class A or higher wattage class AB.
Wenslauw
Wenslauw
Do you have examples of such amps?
Doodski
Nothing new and current but I think for your price range you should be able to p/u something new or even used. You open up a entirely different selection of gear to select from. There are people that care for their equipment and are enthusiasts.
Wombat
Australia
Uh-huh is ambiguous: https://www.urbandictionary.com/define.php?term=Uh-huh and distinct from Huh: https://www.theatlantic.com/health/...eans-the-same-thing-in-every-language/281359/
Uh huh probably means do tell(us more for confirmation) re claims when used on ASR. It could mean "not that old chestnut again" or …………. .
