Biblob
- Joined
- Sep 13, 2018
- Messages
- 635
- Likes
- 604
Maybe some of you already now, there is now an updated RB Pi 4 module, that's called the Pi 400. This has an integrated keyboard and has some small performance updated compared to the Pi 4. It did lose the audiojack from the Pi 4b.
Now OSA Electronics released a DAC/ADC module used specifically for the Pi 400. The DACBerry 400 S. Might be of interest for some of you . It costs only € 20.
Here is a link.
The published specifications are as follows:
Analog soundcard
– DAC SNR 102dB @96kHz
– ADC SNR 92dB @96kHz
– THD+N 0.003% / -92dB @1kHz
– Integrated DSP with 3D Effects, EQ and De-Emphasis
– Ultra low-noise LDO for analog power rail
– Gold-plated 3.5mm headset / headphone jack (mic in – stereo out)
– Low-Noise design with isolated Digital and Analog parts
– Directly powered from the Raspberry Pi / Tinker Board / Jetson Nano and others with compatible GPIO
– Compatible with Raspberry Pi 400
– Compatible with all Raspberry Pi’s with the 40-pin connector and Asus Tinker Board and othes (Odroid, Banana Pi..)
– Compatible with OSMC / RuneAudio / Volumio / Moode / PiCorePlayer / PiMusicBox / OpenELEC and others
Here is a link.
Analog soundcard
