New SMSL A300 BTL Class-d Power Amp
SMSL-Mandy
SMSL A300 Hi-res Power Amplifier 165W*2 BTL Mode Bluetooth 5.0​
This is the new power amplifier
  • Input:RCA,BT,USB
  • THD+N:0.004%
  • SNR:103dB
  • ChanneL separation:85dB
  • Cutoff frequency (in high pass mode):50Hz
  • Input Sensitivity / Input Impedance:28OmV/22kΩ
  • Output Power:
  • Input:RCA,BT,USB
  • THD+N:0.004%
  • SNR:103dB
  • Output Power:
    • Stereo 165Wx2(4Ω) / 85Wx2(8Ω)
      BTL 330Wx1(4-8Ω)
  • Power consumption:40W(normaL voLume)
  • Size:210.5X41X198mm(WxHxD)
  • Weight 1.3kg / 2.86Lbs
Click for more Pics: https://hifi-express.com/products/smsl-a300-hi-res-power-amplifier
  • Hi-res AUDIO certification
  • Germany’s Infineon’s new digitaL high-power ampLifier chip
  • Japan’s NJRC company electronic voLume control chip NJW1194
  • BTL Mode(Bridgetie load) 165W*2
Greater power! It can be Bridgetie load into a single-channel amplifier with higher power to drive a large speaker!
Can form a 2.1 audio system
  1. The built-in high-pass fiLter circuit can fiLter out the subwoofer, drive the main speaker, and cooperate with the subwoofer to form a 2.1 system.
  2. Equipped with subwoofer signal pre-output, it is convenient to connect active subwoofers to form a 2.1 system.
  • Bluetooth 5.0
  • SMSL 5DB patented sound effects
  • Can form a 2.1 system
  • Audiophile Audio Components
  • High-quality dedicated switching power suppLy
  • Newly designed remote control
Eric.D
Hello Mandy, would you be able to clarify please at what % of THD+N is this figure... @1% or 0.1% etc.?
JSmith
Looks like it's between 3-5%
H-RYCAJ
If you get two units, you could run a 2.2 system for little to no money. BTL mode states 330Wx1(4-8Ω). What is the load for 4 and 8 ohms, respectively?
Edit: Sub out is fixed to 100Hz and below?
High pass is fixed at 50hz, or is this a mode that can be enabled/disabled?
Manual?
Rottmannash
Nashville
This is an integrated amplifier, not a power amplifier.
Then why do they call it:
TimW
Seattle, WA
I am contesting their description.
A typical power amplifier such as the Benchmark AHB2 has one set of inputs, one set of outputs, and a power switch. That's all a power amp needs to have, but sometimes they also include things like trigger input, gain settings, VU meters, loop outputs, A/B speaker selection, etc.
When an amplifier has multiple inputs, volume, a remote, tone controls and crossovers it is not a power amplifier in my book. It is an integrated amplifier. Add a tuner and it would become a receiver.
JohnnyNG
Manual?
I love that the feature is included but it would seem strange to have LP fixed at 100Hz and HP fixed at 50Hz. From what I can tell in the manual, HP can be defeated but not adjusted.
What are the slopes?
TjindarSingh
Pfungstadt
Same modes as Sabaj a20a and same infenion chip I think.
Reactions: mx2
robertospeed
Italia
I currently have an SMSL AO200 and I like it very much, I would really like to try this SMSL A300 and maybe do a nice review on my youtube channel too, I'm waiting for it to be sold on Amazon Italy
Astoneroad
a Cave in the desert
Forgive the ignorance of this question, with the amp being BT enabled, do I need a separate streamer or could I stream from my phone or PC directly to the amp? Thanks in advance.
Matias
São Paulo, Brazil
mdsimon2
Detroit, MI
What is the source of this graph, where did you get it from please?
Michael
muslhead
if you were to buy two and use as mono's, how would you control volume to insure = output?
Berwhale
It looks like the 1st A300 drives the left speaker and passes the right channel of the input signal out the BTL-R RCA connection which would then be connected to one of the left inputs on the 2nd A300. I would presume that the volume control on the 1st A300 controls the level of the BTL-R output and therefore the volume of the 2nd A300, although it doesn't state this in the manual...
muslhead
that would be nice to think they had an answer to this since they are clearly advertising btl capability. Another answer i guess would be to put a dac with volume control in front of it in the chain
Berwhale
The A300 has a USB DAC and Bluetooth inputs, however, the manual doesn't mention if these inputs can be used in BTL mode or if their right channel is passed out the BTL-R connection.
