New SMSL M500
Jaysz
Should the 2v rca output be enough to drive my power amp
Was ok with preamp had
Not even half the volume now
Noob
@Urushi could you be persuaded to send your RNHP to Amir for testing? It's an amp that I would really like to see detailed measurements for. I know it can feel bad having your gear away for any length of time, but it really benefits the entire audio community.
mkawa
does anyone else get big pops when the unit turns on/off?
Toku
Japan
The M500 generates pop noise when the AC line is turned ON/OFF. It is a disappointing point as a product.
Reactions: pos
mkawa
just making sure it's not my unit alone.
Toku
Japan
Mine doesnt make a noise
Noise occurs when the power switch on the back panel is turned ON/OFF.
There is no noise when the front panel knob is pushed to turn the power ON/OFF.
Because this operation is sleep ON/OFF operation. So in this case, even if it is turned off, the main unit is still working and the case is hot.
ichonderoga
I've seen several places in this post that both LINE outputs are active a once (RCA + XLR) - Would it be possible to connect a SUB to the RCAs and a Power AMP to the XLRs and do digital volume control on the M500?
digicidal
Sin City, NV
Should be fine since your sub has a crossover selection (as do 99% of them). You might have to adjust the level (on the sub) as I presume the output levels (on the DAC) are different for XLR/RCA... won't know for sure until someone tests it however.
ichonderoga
Yeah I really hope so. Would really like to simplify my audio supply chain.
Jaysz
Mine doesn't make that pop noise
My led does turn magenta when tidal software decoding if on
Tidal Passthrough box greyed out
The manual is not clear to me should I have it so led is blue or magneta
J
NielsMayer
Newport Beach, CA
Curiosity killed my cat when i saw the m500 available domestically (USA) on amazon prime with "free returns".
I will keep it for the month timeframe but I already know it's going back. It sounds **great** feeding my Hypex nc400 monoblocks, but it's like being sent a new racing red ferrari with a rev-limiter -- because at "maximum volume" (40) they basically reach "comfortable listening level" for working or concentrating with music on. If I really wanted to listen or just rock out, I could easily be listening at twice the actual volume. For comparison my old Topping DX7s would be at about -40 to -45 dB to achieve the same level as max volume on the M500 ; whereas "too loud" and "disturb the neighbors" levels could be reached with a normal "pop" recording at -25 to -20 dB. So in reality I'd like the XLR outputs feeding the nc400's to be at least 20dB hotter.
The weird thing is, the very first time I hooked it up to my computer (Atomic Pi running Lubuntu 19.04 with a custom KDE-styled and window-managed LxQt desktop) it achieved "normal" volume levels with non MQA files. Then I tried MQA on Tidal in Kodi (via Tidal2 plugin) and it got very quiet. I had to turn it up to 100% to achieve what i'd call a "quiet" listening level. Amazingly, as long I kept the kodi volume control at 100% the blue MQA decoding signal came on, displaying rates from 192k (John Coltrane "Blue World"), most displaying at 96k, and a few labelled as MQA still show 44.1k. The "quietness" didn't seem to be directly associated with MQA as the Kodi volume control (which i try not to use) reduced the volume linearly even though the display went back to normal PCM as soon as the kodi volume was reduced.
I never managed to get it back to the initial "loud" mode for normal non MQA files, even though I factory reset it several times and rebooted my linux machine for additional application of voodoo and cargocultism (when in doubt, reboot).
I also got it to completely puke and emit noise until I power cycled it trying to listen to some DSD demo music I have "ifi-micro-idac2-music-sampler"... Likewise, it pops and clicks through the speakers with totally indadequate or missing output muting relays. Switching inputs, or booting computer, causes clicks. Powering up from the front panel -- causes clicks and pops. POwering up from the back panel (as expected) a much bigger pop. No relays head cycling when power is applied so clearly there are no output protection relays to prevent pops during powerup. That's not acceptable in a $400 DAC.
Oh, and if you change inputs from the front panel, it'll continue displaying the previous input on the LCD (bug). Switching via remote displays proper input.
One thing I was worried about was the device having problems with mixed MQA and normal tidal playlists. I was worried it would go from normal loudness to very quiet on the MQA files. But in reality it goes into "quiet mode" and stays there -- maybe at best a -3 to -6 dB difference in MQA playback over normal. But nothing where it's at normal level (at 40/100% volume) and then suddenly blasting the full 300-400W per channel of my nc400's into my speakers rated at like 160Wpc. Which would suck.
Oh and compounding the issues -- the headphone ouput is absolutely too quiet for reasonable listening - at least into my easy-to-drive ATH MSR7's. Since I couldn't really get them loud enough to compare, i can't say whether the headpone amp is any good. Sounded clear at least.
This experiment answered one of my major questions about using Kodi and Tidal2 on Linux with MQA decoding. I figured it would need passthrough mode setup in Kodi and would only work in SPDIF. However that was not the case. Passthrough was not needed. Likewise I didn't even need to setup Kodi to access the M500 in SPDIF mode. Note that my setup, as is de-riguer for any Linux setup for serious audio, has no pulseaudio (biggest POS in all of linuxdom). Such output straight to ALSA allows my gstreamer-based Qt apps (see http://trainspodder.com ) to do bitperfect audio on Linux even though thats not the goal of the app.
The experiment also semi-conformed that kodi with volume at 100% is "bit perfect enough" to allow the MQA stream to be recognized. Likewise I didn't need to worry about potential conversions that can be invoked in using the ALSA "Default" device as would occur with the following ~/.asoundrc setup:
pcm.usb_m500 {
type hw
card M500
device 0
pcm.!default {
type plug
slave.pcm pcm.usb_m500
ctl.!default {
type plug
I noticed no difference in the output stream or MQA decoding when switching between ALSA talking to SPDIF device versus default "analog" device using an alsa "plug" as intermediary to the audio device.
As to sound, it sounds better than my topping Dx7s, even if the M500 can't approach anywhere near the normal 4Vpp XLR output levels (which would translate to ear-blowing and speaker-blowing levels out my Hypex nc400's).
Compared to the dx7s, the bass is "stronger" -- not necessarily louder, but faster, and "thumpier" . Since that's one of the fortes of the nc400 especially combined with the Adantes.... you can really notice when you're being held back by your DAC or preamp. The M500 significantly lifts a veil off the sound, IMHO, compared to the dx7s. And that's even at low volume levels with the M500 at 100% volume.
Imaging seems better too, and there's a nice clarity to the high end that is not "etched" or bright, but rather "shiny" and "smooth". Feels natural, not fatiguing.
As is typical of SMSL, the build quality is inferior to the "feel" and solidity of the Topping DX7s. The control knob feels a little "wobbly" (not loose, but there's maybe a 1/2 to 1/4 mm of "play" that you can feel and makes it feel cheaper than it should be). But it really makes me wonder how many cycles of clicks it'll handle before wearing out.
This is the second piece of SMSL equipment (went through two pairs of A8's when they first came out before giving up on them due to concerns of longevity and display problems, as well as a feel of "skipping" registering movement on the volume knob) that had a faulty optical SPDIF "door". It basically stays open and stuck, and at the same time, the cable itself won't snap into place.
So even without the volume problem, it's going back (at the end of the month) due to the faulty optical SPDIF. And concerns that the volume knob will suffer the same fate as the A8's prior to its return. Of course, it has the same problem as Topping Dx7s with optical out on my samsung tv -- audio drops out regularly. (But works fine with optical SPDIF input on my Terratec DMX6fire card with my "Mudita24" control app for the card).
Overall I didn't like the physical features of the M500 even before ordering. I don't need optical inputs, and I certainly don't need two. I could have used an additional coax, or even better AES/EBU input - which I like to feed via a 75-110 ohm transformer to further isolates my noisy desktop from the DAC. Well I won't need to worry about that w/ the M500 because I'll be forced to manually plug SPDIF cables on the single SPDIF input. Sucks.
Likewise I don't like the odd shape. I much prefer the flatter shape of the Topping DX7S D70s, etc.
I'm hoping the D70 bluetooth version goes on prime with free returns because that'll allow me to evaluate the two DAC's side-by-side.
I'm wondering if the D70 has (as has been complained here) weaker bass compared to the M500. Might be same thing going on with the DX7s in comparison -- basically it's the sound of "output coupling capacitors" or the slew rate of the output op-amps, or the use of too-large series resistors driving the XLR output to prevent line-ringing problems typical of op-amps driving capacitive loads (e.g. audio cable). Conservative output designers like seeing clean signals on their scopes for ringing that can't be heard, but it significantly affects slew rate and "thumpiness" of the bass.
When are they going to make a DC-coupled audiophile DAC -- you know, like musicians get so they can also do "control voltages" to the modular synths or light controllers. And so that we can get a proper and not phase-damaged "thump" aligned across the frequencies from our loudspeakers. For example Presonus' Quantum and Studio lines feature "DC coupled line outputs" https://www.presonus.com/products/Studio-1810c
Anyways, that's my review after 6 hrs of ownership and listening.
-- Niels
Sak
Japan
NielsMayer
Thank you for your review and impressions.
NielsMayer
Newport Beach, CA
I have an additional comment and hunch regarding the "quiet" XLR outputs on the D500 -- which may affect your usage w/o preamp directly into amplifier w/o volume adjustment. It will be fine for those hooking to active studio monitors since those offer input amplification adjustment or trimming. In my case, I have no such capability -- I'm stuck with whatever hypex has decided is the right amount of gain for an amplifier: https://www.diyclassd.com/img/upload/doc/ncore/nc400/Documentation/NC400_04xx.pdf ... for all the other DACs I've tried with "pro" levels this has not been an issue. For the M500 I suspect it outputs "consumer level" even to the XLRs.
So my hunch is that the output levels to the XLR's are not the expected "pro" levels, thus the quiet output. XLR output should have a minumum of 3.472v PP (or 1.228v RMS per following link) or +4 dB. Consumer level outputs are less, listed in following link as 316mV RMS, 0.894v PP or -10dB. https://www.sweetwater.com/insync/understanding-signal-levels-audio-gear/ https://en.wikipedia.org/wiki/Line_level#Nominal_levels
So my initial "feel" for needing an additional 20dB is about right for having consumer output levels on the XLR -- they'd by down by -14dB.
If you look at the specs, you see that the balanced output has a higher dynamic range (125dB) than the unbalanced (120dB). Although it's a little counterintuitive, since the balanced output offers common mode noise rejection and overall lower real world noise .... The problem is that a balanced output requires twice as many op amps per output, which means twice as much noise. So IMHO in the real world a "real balanced output" doesn't ever have a significantly better spec than the unbalanced. For example the Dx7S has 123dB dynamic range on the XLRs versus 122dB on the RCA's.
So add the above two hunches and you get -- this unit is using the same output opamps for the XLR and RCA, and using "fake balanced" outputs which looks like the "line output" below (or alternately and more reasonably, using a dual op-amp configured the same for each channel, with one output to RCA, and the other to a "fake balanced" output like this:
images
Fake balanced offers the same common-mode rejection (courtesy the differential input op-amp on the other end of the cable, has nothing to do with output), and the above architecture is half the cost and half the noise. Probably not as good for driving a 100ft balanced run in a pro audio install, but at least measuring better and not doing much harm in a normal amateur studio or home.
The only thing is you need to remember to have two sets of outputs, or a switchable output with 14dB more gain for the "pro" level outputs. And I have a feeling SMSL didn't to that.
Anyways that's my hunch. Since I'm returning my unit, I'm not going to open it and find out what the actual output circuitry looks like.
But the 125dB balanced vs 120dB unbalanced, to me, suggests they're getting all the noise benefits of balanced, without the added noise and distortion and slew-rate limitations of a second op amp cancelling most of it out. It might actually be why it sounds better (in addition to the "pro" version of my earlier DAC) w/o needing to resort to a fancy discrete output stage with pairs of discrete class-A output transistors or FETs wasting lots of power 24/7. Because op-amps are noisier, but easier and more mass-production-friendly, they can use a single high quality amp per output instead of a pair and that's going to be cheaper than the discrete solution for a high quality "real balanced" output, while overall still giving good specs and sound for "amateur" setups with short cable runs.
Anybody got a close-up of the output circuitry to verify? Wasn't there some prior discussion of "less op amps" -- a fake balanced output allows exactly such a solution: less op-amps, better specs, and potentially better sound (half the distortion&noise, double the slew-rate) for less cost.
-- Niels.
masonHsieh
Melbourne
-- Niels
That's a very good review. I have been using m500 for a couple of weeks on my Windows laptop, and I didn't try to test it on my Linux machine(Arch+i3) until I saw your post. I didn't test any MQA files but was having a hard time setting up the sample rate through the Pulseaudio. I manage to set up the sample rate to 384khz for PCM by modifying a few lines in '/etc/pulse/daemon.conf'. And I couldn't find the XMOS driver and official SMSL m500 driver for Linux version from the SMSL website, I am not sure whether it may be an issue in the future.
In case if anyone has a similar issue as mine, here is the related page you can look at:
References:
https://linux.die.net/man/5/pulse-daemon.conf
https://bbs.archlinux.org/viewtopic.php?id=245907
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
images
-- Niels.
I believe Amir is getting one for testing shortly, so I look forward to what he finds as well. I appreciate the time you took to post your impressions.
Jaysz
Been contacting shenzhen audio to see why the output volume is so low on all sources and formats with rca and xlr
Even connected to some active studio monitors
The manual shows filters only work with non mqa but only work with mqa
Heres the reply
Doesnt say why output low on non mqa
mkawa
for reference (this image is also earlier in the thread). M500
sabaj d5
the thread guessed earlier that the m500 is in current output mode (which makes some sense since increased current is a perk of the 9038 pro)
i suspect the only way to know what is going on for sure is going to be to wait for amir's measurements.
the m500 is going directly into my power amp that has 29dB of gain and i have not had any volume issues. i haven't tried DSD input but i will actually do that now, because that's quite bad if it actually can't handle DSD..
armani006
I did listen to DSD 128 yesterday via XLRs and Foobar 2000 (you have to adjust foobar to DSD), all goes correct and perfect.
mkawa
am listening to some dsd sample tracks right now as well.
also, i had emailed smsl during golden week to see if there were any firmware updates and there is currently nothing newer than r1.4
"Oh, and if you change inputs from the front panel, it'll continue displaying the previous input on the LCD (bug). Switching via remote displays proper input. "
i also don't get this..
which firmware version is your device running?
