New Sony MDR-MV1 - Professional Open Back Headphones
VintageFlanker
Paris
This does not happen very often : Sony just released new professional / reference (and open back) headphones:
MSRP seems to be about 400$, as for EU, it is already listed at Thomann for 474€:
Specs:
Type
Open back, Dynamic
Driver unit
40 mm (1.58 in)
Power handling capacity
1500 mW (IEC)
Impedance
24Ω at 1 kHz
Sensitivity
100 dB/mW
Frequency response
5 Hz - 80 000 Hz (IEC)
Mass
Approx. 223 g (7.87 oz) without cable
Included items
Stereo Headphones, Headphone cable (approx. 2.5 m (98.43 in), stereo phone plug), Plug adaptor (approx. 20 cm (1.58 in), stereo phone jack↔ stereo mini plug)
raif71
From the pictures, no pentaconn jack ?
VintageFlanker
VintageFlanker
Paris
24Ω seems to be an odd choice for a dynamic headphone built for studios, where high output impedance headphone amps are still pretty common.
I second this...
Nope. 6.3mm SE jack on the amp end (they could have it balanced, tho, since the headphones jack is 4 poles)
okok
looks no good, no more than $20, better go check the bin stores
Fregly
They do not provide a frequency graph, unless I missed it, so right it away my scepticism kicks in. I assume it's crap without measurements. The is just the basics if one is a rational agent.
GXAlan
There seems to be a personalized HRTF option for recording/mastering/mixing engineers who live in LA, NY, and Tokyo.
VintageFlanker
VintageFlanker
Paris
So far, most, if any FR graphs provided by headphones manufacturers have been proven either wrong or unusable (overly compensated or smoothed, very high vertical amplitude)... So, AFAIC, I do not care if they publish some or not. What I do need for are tiers measurements, preferably from different sources.
Doodski
Not so sure about that connecting 3.5mm or 2.5mm 4 conductor jack on the headphone cup. The retention spring strength of those connectors usually is not meant for vertical loading with movement and tugging.
Tremolo
Italy
40 years and the look of sony's "pro" headphones hasn't changed much. I hope they have bigger cups and sound better than v6
restorer-john
It is threaded.
"The connection part to the main unit is detachable with a screw system, allowing for secure connection and cable replacement."
