New Subwoofer installed, help analyzing REW plots
D
Deleted member 65
Guest
Installed my first ever subwoofer and need help analyzing and optimizing my setup.
Reason I had to purchase the subwoofer is entirely to blame on my 4 year old granddaughter. Due to her dancing and running I had to save my floorstanders and replace them with my second setup monitor speakers which are more or less impossible to rollover.
Bought an Elac Sub 2050 subwoofer.
D
Deleted member 65
Guest
Done some initial REW measurements, this is what they look like:
Without Sub installed :
D
Deleted member 65
Guest
With Subwoofer installed (Blue) LP 70, Vol 50:
D
Deleted member 65
Guest
Waterfall w sub:
Purité Audio
Industry Insider
Barrowmaster
London
I find if I go to ‘graphs’ and hit the 1/48 smoothing button the plots are easier to look at.
Krunok
Zg, Cro
If that is a single log sweep measurement taken from your listening position than it looks as your subwoofer is doing a good job. You would get much better picture if you make at least 5 log sweeps from various positions around your listening position, average them and apply 1/12 smoothing.
Or, even better, you can do a RTA sweep by moving the mic around your listening position. It's explained here.
This post will also give you a basic idea.
Ron Texas
Both the mains and the sub are responding to the room in a similar way. Try moving the sub somewhere else to see if that tends to flatten things out a little.
Krunok
Zg, Cro
If this is a single log sweep measurement it cannot be flat be flat at any position. Single sweep would hardly be flat even with Room EQ in place.
Ron Texas
What I am thinking is the sub and mains might respond differently with the sum being flatter than it is now. If the measurement method is deficient, use a different method.
Krunok
Zg, Cro
You cannot rule out this position without proper measurement. When you look at the photo with that cornered wall and the door I doubt this can be any flatter without room EQ. But nothing can really be concluded from a single sweep.
D
Deleted member 65
Guest
Thx all,
I'll do some more measurements tomorrow, not allowed to measure any more tonight.
Below you can see current setup, I'll see if I can replace the rack with a smaller one and have the sub in between the speakers.
Ron Texas
That's a nice room. I bet there are piles of snow outside, something that doesn't happen here.
Ron Texas
I found moving my sub around made a huge difference. I used this: http://www.szynalski.com/tone-generator/ if I heard the volume change as I stepped through the frequencies it gave me an indication of what was happening. The variation was audible, by definition. I don't have test equipment or a calibrated microphone and probably would not know how to use it if I had one. It's an unscientific trial and error process, but it produced results.
Krunok
Zg, Cro
Trial and error is a legit scientific process. :)
Your equipment would do even better if you measure it properly and do room EQ. I'm sure you can do it, it's not a rocket science.
Krunok
Zg, Cro
Thx all,
Your setup looks very nice and having fireplace between speakers is awesome! :)
D
Deleted member 65
Guest
Subwoofer now moved into final position in between speakers. New smaller HiFi bench (Ikea!) installed to accomodate space for the subwoofer.
- Eight (8) new REW measurements, 1/12 smoothing applied.
- Low Pass set to 70 Hz.
- Volume set to 50.
Average SPL&Phase:
Krunok
Zg, Cro
- Volume set to 50.
Average SPL&Phase:
This is average of 8 log sweeps? Where was the mic in each position?
