Here's the output of my DAC running in 24/44.1 NOS mode (1kHz sine wave input):
How many bits were used in the generation of the tone?
Your understanding is correct. JA doesn't know what he's talking about.In a recent BorderPatrol DAC review in Stereophile, JA refers to it as "aliased image energy". This makes no sense to me. My understanding is that "aliasing" occurs during analogue-to-digital conversion, where any signal above the Nyquist frequency is 'folded back' in-band. "Imaging" occurs during digital-to-analogue conversion, where any signal beyond the Nyquist frequency is 'replicated forward' out-of-band.
(I've noticed Amir using "aliasing" when talking about DACs too.)
Is JA correct to use the term "aliased image energy" for NOS DAC in-band distortion? If not, what's causing it?
No more than differentiation and integration should.So, "aliasing" and "imaging" really shouldn't be used interchangeably.
Sloppy use of terminology when the meaning is clear is one thing. JA's case is different. He seems to have a very distorted understanding of how these things work.I've seen many times images called aliases, people have problem understanding terminology but you usually know what they mean through the context.
Use 1001, 1005, 1010 Hz instead of 1000 Hz and see what happens.The 22nd harmonic lies at 22000Hz. The first image of this beyond Nyquist is at 22100Hz. The difference is 100Hz.
It's definitely IMD .
Mani.
Or 1500 hz. I've taken to doing IMD measurements at 18.5 khz and 19.5 khz. That way the sum and difference from the various even and odd orders don't end up on top of each other.Use 1001, 1005, 1010 Hz instead of 1000 Hz and see what happens.
I am more interested to see 20khz measurements, for NOS it should look shit
then if -80db sounds likely still inaudible, the waveform is interesting thoughIt does. At -80dB, it looks like noise.
ok, that don't look really like a sine wave but it is not as bad as I would expectMy scope can't resolve down to that level, it has 8-bits resolution with 12-bits software interpolation. Maybe someone with a higher resolution scope can post this. Here's 20kHz @ -70dBFS, Holo Spring NOS mode:
20kHz @ 70dBFS (ref +19dBu) NOS waveform ("NOS" of my Adi-2 Pro):My scope can't resolve down to that level, it has 8-bits resolution with 12-bits software interpolation. Maybe someone with a higher resolution scope can post this. Here's 20kHz @ -70dBFS [...]
Or 1500 hz.
