- Joined
- Oct 25, 2019
- Messages
- 11,112
- Likes
- 14,777
@Robbo99999 I am on a Mac, but have an RME ADI-2 DAC. I don't think Oratory has provided RME specific settings, but I think I can get away with setting some of them. I was thinking of starting with bands 4, 5, and 6. Plus the EQ -7dB. I don't mind the extra bass. Just have to read the manual and figure out how to set those. Thanks so much for all the help, by the way.
If you look at the PEQ settings for your measurement of choice https://github.com/jaakkopasanen/AutoEq/tree/master/results including Oratory - you will note the first 5 of the 10 PEQ settings are the prime ones, the second 5 are the secondary "smoothers" You might apply the first 5, or maybe use the heaviest of the fixed band EQ frequencies in the table below PEQ.
