OCD hiss situation
Barry_Sound
Im getting a very tiny amount of hiss when I put my ear right up to the tweeters, no matter the volume of the amp, no matter what source is selected. Interestingly it goes dead silent when I unplug one of the speaker cables (left or right).
It´s not audible from a typical listening point but my OCD wants the speakers to be totally off when no music is playing. ;)
Any idea? Thanks guys
Galliardist
Sydney. NSW, Australia
Well, first of all we'll have to guess what your equipment is....
B
Barry_Sound
Got you, sorry. It´s a full size class A/B amp with passive speakers. Only a DAC connected at this point, no phono, nothing exotic.
Sokel
Again,we have to guess your speakers sensitivity,your amp's noise and gain,etc.
You have to be more specific.
B
Barry_Sound
Thanks, I dug up the specs …
Speakers Wharfedale Elysian 1
Amplifier Quadral Aurum A9
B
Barry_Sound
… and the type and make? So we potentially would find independently measured performance and wouldn’t have to rely on the specs only?
Plus the DAC?
Added the brands and names, maybe it helps? The DAC is unrelated. I can unplug the DAC and its still there.
staticV3
According to those specs, the Aurum A9 is a very noisy Amp with ~4mVrms of A-wt noise (20Hz to 20kHz BW).
For reference, modern Cass A/B or Class D designs from Benchmark, Purifi, Neurochrome, Hypex, Topping, etc. tend to have about 10μVrms of A-wt noise.
That translates to 50dB less noise, or about 3% of the audible hiss of the Aurum A9.
unpluggged
45 dB of gain do not make things easy...
staticV3
Possible. Does this fit in with that the hiss disappears when one speaker cable is removed?
Could you perhaps elaborate on that?
Do you mean that if you disconnect one cable from one speaker, let's say the negative cable of the left speaker from the Amp, then the left speaker stops hissing?
Or do you mean that if you disconnect one of the four speaker cables connected to the Aurum A9, then both speakers stop hissing?
HarmonicTHD
If you take the very high 4mVrms noise, which staticV3 has derived from your amps spec, convert it into watts and plug it into a SPL calculator, yes you will indeed get audible noise at that distance. Sorry to say, your amp is simply too noisy. Modern amps, such as mentioned above, are dead quiet. (Not that it matters for acutal listening, but since you asked).
B
Barry_Sound
Naturally, by disconnecting one cable, the circuit is interrupted and current can no longer flow.
Where there's no current, the speaker membrane cannot move and therefore cannot produce noise or hiss.
True, I´m leaning towards the "amp is noisy by design" explanation then. So no easy fix except of getting something different... :facepalm: ;)
HarmonicTHD
Yes. Sorry.
Just to give you a perspective ... and it is just one option of many .... modern, well engineered and performing electronics dont have to be expensive.
For example at ca. 700EUR, this was tested here recently (and of course there are others, but we would need to know, what inputs other than DAC you need etc.).
It has ca. 110db Signal to Noise Ratio, which is 56 times less noise and when you deduct the ca. 35dB from the 52dB SPL above you will get ca. 17dB SPL, which can be considered very quiet (Keep in mind a quiet room has ca. 30dB SPL on noise already). It has ca. 200W output and and a good DAC included. So if you were to sell your existing equipment, you would probably have money left to spend elsewhere.
Ruhled
If you can only hear it with your ear right up to the tweeter I don't think there's much benefit in "upgrading" but to each their own. Keep in mind no amplifier is 100 percent silent. The noise is there even if you can't hear it. :)
sergeauckland
Suffolk UK
I actually like a small amount of noise as long as it's only audible close to the 'speakers, as it helps to confirm the amp is working.
S
ta240
S
Usually the music coming out of the speaker does that for me....
