AudioStudies
- Joined
- May 3, 2020
- Messages
- 718
- Likes
- 401
Ya sure as hell got that one right . . .It will.
Get the Supra, that’s an exciting Toyota! Wait... is it really a Toyota?...A Toyota just doesn't excite me
I have to stick with the Jag, I installed a high-end audio system so don't want to give up on it quite yet.Get the Supra, that’s an exciting Toyota! Wait... is it really a Toyota?...
Some real elitist nonsense the should be shunned by anyone who cares about good music reproduction and hearing quality products.He didn't invent it. There used to be brick-and-mortar shops that demanded a non-refundable deposit before any demos or discussions. The deposit would be applied to any subsequent purchase. Not missed.
Yeah. We had one of these in my neighborhood when I moved in almost 30 years ago. He later moved to a smaller shop on a side street and, subsequently, disappeared. Of course, a lot has changed and/or disappeared over that span of time but the more traditional shops have endured, so far..Some real elitist nonsense the should be shunned by anyone who cares about good music reproduction and hearing quality products.
Actually it's a Bimmer.No, it is a transformer toy morphing from a Miata to something else but getting stuck in the middle of the transformation.
I remember going to some high end stores in downtown Chicago back in the 70-80s. There was a shop called Paul Heath Audio on N Clark St and another who's name escapes that was right down the street. They were the cream of the crop TOTL back in the day. I would pull up on the sidewalk right in front and get off one of my straight piped Harley choppers wearing old jeans and my cut vest. The sales guys would run for the back room like John Dillinger just walked thru the door. LOLYeah. We had one of these in my neighborhood when I moved in almost 30 years ago. He later moved to a smaller shop on a side street and, subsequently, disappeared. Of course, a lot has changed and/or disappeared over that span of time but the more traditional shops have endured, so far..
Two things you need to know:
Noise floor of AP is high 4uV for 5V range
I'm 100% positive you will not see anything except noise. Multitone test is a way more difficult test for the device. To show anything above noise floor in time domain, sine wave is the only option. And you will only see -120db.
APx500 series audio analyzers have the required program simulation noise signal built-in to the signal generator. In certain APx measurements, it’s available by setting the generator Waveform to Noise and the Noise Shape to BS EN 50332-1.
If you have an amp with SINAD of 113 dB and you put a DAC with SINAD of 113 dB, the resulting SINAD for both will be 110. So you do lose fidelity.One stupid question and I apologise for my ignorance, but for example since the best power amplifier measured in ASR: Benchmark AHB2 has a SINAD of 113db and it seems that the bottleneck in a system is the power amplifier as far as electronics concern, does it really matter if the dac has SINAD over this value? I mean what is the point in a system of having a dac of 120 SINAD if you have a power amplifier of 105 (Hypex NC400 for instance)? Do you actually gain anything or it is just a cool number and you have pride of ownership?
For the DAC to have negligible impact on SINAD of the amp, it needs to be 10 dB better or 123 dB. In that case, the system SINAD drops to 112.5 dB so not much impact.
Maybe we could use a little combined SINAD calculator app.
https://www.audiosciencereview.com/...rements-of-essence-hdacc-ii-4k-hdmi-dac.7171/If only we could get a unit that is a mashup of the two Okto units with Optical inputs for 2.0 PCM, USB for PC connection and a HDMI port (just 2.0 to LPCM 7.1 no licensed Dolby/DTS nonsense, no 4k pass through etc), this would make for a fantastic lightweight pre-amp for a mixed music/HT use that would be totally transparent for both uses.
Yes, I know the primarily music guys will jump up and down foaming at the mouth at that "travesty" at the mere mention of HDMI but if I had a nickel every time when someone declared what they need is all that matters, I would be very, very, rich.
This essence unit appears to have a USB input in addition to the HDMI input. However, in the specs it calls it a "propriety service" input. Does that mean that the USB is for firmware upgrades only? Or can it serve as a USB input from a computer for audio use?Particularly for $300. It also does "LPCM 7.1CH, Dolby TrueHD, Dolby Digital Plus, Dolby Atmos and DTS-HD Master Audio".
Sorry, I do not own one and cannot help. Their support line should be the best contactThis essence unit appears to have a USB input in addition to the HDMI input. However, in the specs it calls it a "propriety service" input. Does that mean that the USB is for firmware upgrades only? Or can it serve as a USB input from a computer for audio use?
and it's brother
https://www.essenceelectrostatic.com/product/evolve-ii-4k-hdmi-v2-0-multi-channel-dac/
not exactly Okto level of perf but more than good enough. Particularly for $300. It also does "LPCM 7.1CH, Dolby TrueHD, Dolby Digital Plus, Dolby Atmos and DTS-HD Master Audio".
That pair has similar issue as the Okto pair even if they are not in the same league as Okto. If you want volume control and source switching, you get only stereo. If you want multi-channel, you don't get switching and you don't get volume control (unlike Okto). Like Okto, these also leave you wishing for a mashup of the two.
