Okto dac8 stereo DAC Review
beefkabob
Yes the only thing that matters is the SINAD coming out of the binding posts of the final amp in the system. That result will be identical from the binding posts of the Purifi or Benchmark AHB2 regardless if the $20 Meizu or the Okto DAC was used as a source.
I'd like to see the test, just to make the point. A Purifi and an ABH2 hooked up to a steller vs merely fantastic DAC, and measure the output.
What this DAC lacks is room correction.
Is it still possible to get the Dirac laptop software?
John1959
Netherlands
From the user manuals:
DAC8 PRO
-130 dB THD
119 dB SINAD
125 dB dynamic range
DAC8 Stereo
- 130 dB THD
120 dB SINAD (or better)
131 dB dynamic range
RichB
Massachusetts
Since I’ve been only using Roon lately, I plan to set it up with RoPiee XL like I currently do with my Pi 3b+.
I tried that and it crashed my network when using WiFi, so I switched to Volumio.
- Rich
RichB
Massachusetts
I can't. My jitter test is 24 bits and airplay truncates that to 16. It also resamples it to 44 kHz which really screws it up.
I had trouble consistently connecting to the Roon endpoint because Roon was selecting AirPlay.
You should be able to get Volumio to accept full resolution by adjusting the settings as shown below:
Install the Roon Bridge
Disable other sources:
Once enabled in Roon, you can stream full resolution audio files.
- Rich
JohnYang1997
China
@amirm Was the bandwidth correct for the dashboard? Would you provide a full screen screen shot where you have the settings for the input?
Thanks in advance.
JohnYang1997
China
These are AP loopback with different bandwidths. As I measured yesterday the output noise is far lower than the equivalent input noise. So the limitation should apply to DAC measurements too. Is the 1 extra dB coming from the different bandwidth?
Another thing is that the dynamic range measurement only showed 127dB, which is the same as element x. So it can't be that noise is far lower on this.
@amirm Is the bandwidth used for dashboard correct?
Sonic delight
View attachment 73368View attachment 73369
Not sure why people pay $30k for an APx-555. I can measure SINAD up to 128 up to 24v, and 116 SINAD up to 100v up to from 20hz to 100khz. And I have only $5K into my setup. Lots of suckers out there!
JohnYang1997
China
Not sure why people pay $30k for an APx-555. I can measure SINAD up to 128 up to 24v, and 116 SINAD up to 100v up to fromm20hz to 100khz. And I have only $5K into my setup. Lots of suckers out there!
What about THD of -140dB? And you can build a noise amplifier for 30 bucks. Then you can measure 140db of SINAD indirectly across wide range of frequencies.
And highly precise frequency, highly precise amplitude. And many more
Maybe you don't really need it for designing a great product but you can't say it sucks and people who have those are suckers....
pozz
Слава Україні
Editor
Please prove your results by starting a new thread and showing measurements.
Sonic delight
My rig can outperform the APx-555 in every area up to 100khz. Far far beyond the threshold of audibility for $5k.
Doodski
The value of metrology sometimes appears bloated but standards are to be referenced and that costs bigger money.
imagidominc
What an amazing DAC! Great review Amir!
YSC
Given that the only amp whose SINAD exceeds the Eval 1 with its buffer bypassed (108 db) is the Benchmark AHB2 (113db), are you saying that this unit is overbuilt for absolutely every amp out there?
As a tech noob I am thinking of one question:
Shouldn’t the source SINAD is always higher the better even the amp is less competent than it? As we have no absolute distortion free stuffs and what we hear is the SINAD sum from dac to amp to speaker or headphone. As the distortion at any frequency can be distorted multiple times. So it won’t be a 100db SINAD amp should only use a dac at same grade ?
Sonic delight
My rig is perfectly calibrated against a reference far beyond an APx-555. Every analyzer manufacturer has a reference rig they use for calibration.
Sonic delight
As long as the Dac has a 1-2 dB better SINAD than the amp it’s feeding, you’ll achieve the same SINAD from the amp output as the best audio analyzer can achieve. Or this DAC for that matter.
