One or two subwoofers with Genelec 8351b
JustJones
I've been considering adding a subwoofer with my 8351b's and I would like to stick with Genelec subwoofers in order to use GLM. In the US I can get 2 8 inch 7350 SAM subs for $1260 per sub or 1 10 inch 7360 for $2560. The 7350 goes to 22hz the 7360 to 19hz. I've never tried to incorporate a subwoofer which is why I would like to stay with GLM. My question is which way would give the best result, my gut feeling is 2 of the 7350 but maybe my gut is wrong and 1 of the 7360 would work better. This is only for a 2.1 or 2.2 system not a HT setup. I couldn't find a subwoofer thread so I hope this is the right sub forum. Thanks for any input.
FrantzM
Hi
Not a Genelec expert. I don't know how GLM deals with multiple subwoofers but I'd go with 2 ... too :D
q3cpma
France
Since Genelec recommends the 7370A for the 8351B, I'd take at least the 7360A with the intention of buying another later on. If you absolutely don't plan on doing this, I suppose two 7350A may be better (equivalent SPL with the +6 dB pair gain and all the avantages of two subs).
On the same topic, I'd absolutely take two 7360A instead of a single 7370A.
J
JustJones
After doing a bit more research I think you're right about using the 7360 and looking into a second later. Thanks
