I have primarily been using a modified 4-screw HiFiMAN HE6 (reduced treble) for the last 6 years or so and an HE500 prior. I've been speaker obsessed the last couple of years and don't do as much headphone listening. That in combination with the fact that these headphones are getting long in the tooth has peaked my interest in trying something new tuned in accordance with the Harman target curve and with low distortion, per the latest research.
Would someone help point me in the direction of the top endgame choices that follow these principles? EQ is on the table.
Also, some bang for the buck options would be nice to consider too. I'm aware that the HD6XX and HD58X are commonly suggested as great bang for the buck options. Are they still the best budget options? Which of the two is considered better for matching the Harman target curve with low distortion? EQ is on the table. Any help would be appreciated, thanks!
