Optical Digital Audio Splitter
RayDunzl
Central Scrutinizer
Riverview FL
Looks fine to me.
graz_lag
Le Mans, France
The only issue you may - or may not face, is the bandwidth limited to 96kHz, although the item's description says up to 192kHz.
You can test it, that is rather 0-1: it works or it does't.
Blumlein 88
It might be fine or it might not. Below are some measurements I made of an HDMI switcher which among other things put out a Toslink optical signal. You might particularly look at the post #9. The clock for that apparently is really poor. It modulated and raised the noise floor, and increased jitter considerably even when connected to a good DAC.
https://www.audiosciencereview.com/...ewhd-prosumer-ultrahd-hdmi-3x1-switcher.1560/
Also post #25 in this thread.
https://www.audiosciencereview.com/forum/index.php?threads/hdmi-to-optical-stereo.2051/post-55155
Now the device you are looking at may be just fine. But at that price things are constrained on quality. You would only know if someone measured it for you, but you might see something like the device I tested above.
westyjeff
westyjeff
Monroe, WA
Thanks for the reply's ! I ordered one and well see how it goes, I could lend it out for testing if anyone is interested.
