Optical in, EQ optical ( ideally) out?
Purité Audio
Industry Insider
Barrowmaster
London
ASR members, I would like to EQ a signal from my TV, I would like to take the optical from the TV add a couple of filters and then ideally send the optical out to my dac.
I could use RME Pro, ( overkill ) MiniDSP Nano DigI would work I believe although I haven’t used one in years is there anything else?
Thanks in advance Keith
DonH56
Monument, CO
Stereo or multichannel? miniDSP may be the easiest overall but you could probably use anything from a Raspberry Pi to a PC to an AVR or DEQx.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Don, I am using the EQ in ROON for my music , but I also want to EQ the TV’s optical output, then input that to my dac, I could connect everything to my RME but it is more convenient to use the Mola which is attached to my network.
I just wondered if there was something other than the Nano Digi?
LTig
Europe
Get a Behringer Ultra-Curve Pro DEQ2496.
