My suggestion for a loudspeaker without compromises for home use , using Linkwitz Riley active crossovers with 24 dB/oct slopes, is like this :
3/4 tweeter without waveguide 4000 - 20000 Hz
3 inch middriver 300 - 4000 Hz
6 1/2 midbass 80 - 300 Hz
12 inch subwoofer 15 - 80 Hz
Would you use different crossover points, or different sizes of the drivers ? Of course everything depends on each driver….
I would also use a rather wide baffle , 38 cm wide to get away without baffle step compensation down to the 3 inch drivers crossover at 300 Hz.
