- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,410
PS: Did you refer to your post #296
Sorry, I meant post #289.
Will give that article a read, thx.
I like the cut of that bloke's jib .So you disagree, then, with Watkinson’s list:
https://www.thebroadcastbridge.com/...echnology-part-15-a-catalogue-of-shortcomings
@Floyd Toole , your position, and many ASR members’, on point source seems to be:
1) Point source is ideal
2) Point source is a theoretical concept that cannot be fully implemented in real life
3) Psychoacoustically, traditionally stacked drivers work just fine, as evidenced by listening tests where researchers used traditionally stacked driver speakers
You didn’t really write (1), but I have never met anyone who hasn’t been in agreement that point source is ideal. So I put (1) there to make this discussion a target for a wider audience.
On (2): Because something, an ideal, is impossible to work out 100 percent in reality, does it mean we should give up the idea of the ideal? We have different ways of engineering things:
a) You can tweak and perfect an old proven design
b) You can come up with a better idea, still unproven, and set out on a journey to realize that idea even if you know that the idea is a theoretical one that can never be realized 100 percent.
I believe I am a (b) person; if someone tells me my idea is an impossibility, I may still spend some time on it because I know option (a) is unchallinging and boring. And I believe that if I realize just a part of a BIG idea, I may still create something which is greater than a perfect realization of the conventional, yet smaller idea.
On (3): All (?) psychoacoustic studies that we normally refer to have been done on conventionally stacked design. How can one use these studies in arguments on the pros et cons of point sources? Isn’t it like running in circles? Shouldn’t point source (attempting) designs be used to evaluate the value and validity of point source design (attempts). My point is, how strong is the psychoacoustic research that we normally refer to? Is it so strong that we can disregard attempts - existing and future - to realize the point source ideal?
Existing point source designs have been proven to have more robust directivity than even a two-way design. So I cannot understand that @Floyd Toole and others think chasing the point source ideal is futile («Good luck with that!»).
Because existing point source designs already have superior directivity off and on axis, I think one should spend more time discussing the drawbacks (and positive sides) of these point source designs - as evidenced by measurements and data - instead of attacking attempts at bridging the gap between idea and real-life engineering.
Let’s not kill the idea of point source without data to support the position that point source is futility.
Some thoughts:
1. I know of no real-life vocal or musical sound source that behaves like a point source. In fact, as shown in Figure 10.18 human voices and many musical instruments have directivities not unlike conventional forward firing loudspeakers. Humans, therefore, are well adapted to listening to the direct and reflected sound fields of such sources - not point sources. Approximations of point-sources are used to measure concert hall reverberation times (pistols, firecrackers, popping balloons, crudely "omni" loudspeakers) on the assumption that an entire orchestra will at different times radiate some sounds in all possible directions . . . or not. It is another of those "academic" notions that becomes a practical norm but which is not an accurate representation of what happens in life. At an Acoustical Society meeting a few years ago there were a few papers by academics who were measuring the omnidirectIonality of popping balloons. To me that is an indication that they were running out of thesis topics that had any potential to contributing to the useful body of knowledge.
2. As discussed, with measured evidence, in Chapter 5, the steady-state room curve at frequencies above about 500 Hz is well estimated from early reflections; first reflections from floor, ceiling and walls. This means that most of the physical energy is in those components, and that perceptions will be dominated by them. Sounds radiated in other directions encounter multiple surfaces and much longer propagation paths en route to ears and are substantially attenuated. Simultaneous and temporal masking will further reduce the audible contributions of those later sounds. As I have said, I know of no evidence that indicates an inherent superiority of "perfect" omnidirectIonality, even in horizontal and vertical planes.
3. Usually, and I assume in this discussion thread, the relative virtues of loudspeakers are evaluated in two-channel stereo. Adding the many reflections from omni loudspeakers is known to reduce the audibly stark illusion presented by hard panned L & R sounds - softening the images and reducing the impression of sound emerging from a monophonic point in space. Also, inevitably, the clarity of the "double-mono" phantom images, including the star performer in the center, is reduced. Some like this, some don't. But all of it exists because of the directionally and spatially deprived performance of stereo - which sadly we are stuck with as the musical norm. Some of us have moved on to multichannel enhancements of stereo, in which one can exercise some control over "reflections". Because timbre and localization are dominated by the direct sound, omnidirectional loudspeakers would not be advantageous.
4. Finally, until mixing and mastering engineers start using omni loudspeakers in somewhat reflective rooms the "circle of confusion" is aggravated when customers start editorializing on things at home. The art cannot be preserved. It is like buying an old master and illuminating it with colored light. Personal preference prevails, but at least the light can be turned off for others.
If I were to be able to return to the world of audio research I would work towards a better understanding of multichannel upmixing. Dr. David Griesinger, when at Lexicon did a superb job of stereo enhancement in the Logic 7 upmixer. It pretty much left the stereo soundstage alone while adding tasteful amounts of envelopment. In the best implementation it was adjustable. Sadly that is gone. Now I am experiencing Auro3D upmixing in an SDP-75 and at its best it is quite satisfying. It too is adjustable. It quickly becomes clear that no upmixing algorithm setting is satisfying for all program material. However, it also becomes clear that reverting to raw stereo is frequently a backwards step. The same is true of loudspeaker directivity patterns. Fortunately, humans are very adaptable.
Thanks, @Floyd Toole !
AES Fellow John Watkinson writes here about the aperture effect:
https://www.thebroadcastbridge.com/...speaker-technology-part-5-the-aperture-effect
It seems like you think this concept is of little value in audio?
Could you point out where Watkinson’s reasoning is flawed?
We also find this... and differences in rooms, and position, and mood, and so onOnly if you deliberately seek out weird, anachronistic speakers (most of them!). If you only listen to speakers designed to be objectively neutral, we find...
The big missing ingredient in the analysis of loudspeaker performance is a measure of non-linear distortion that reliably correlates with perception. The common harmonic and intermodulation metrics are almost useless. That is where perceptual (simultaneous and temporal masking) factors are absolutely required in the metrics.
Thanks for entering the discussion.
Until one gets seriously involved with double-blind evaluations - i.e. almost nobody in the history of audio - it is possible to express all manner of opinions and to lose sleep over real physical phenomena that two ears and a brain take for granted.
2) differences in time delay across frequency (big issue for percussion and other "attack" kinds of signals)
5) Phase coherence (the ear is more or less minimum phase) that is not minimum phase or constant delay. (And constant delay is "ok" only for some kinds of filtering or shaping)
Hi @j_j, would you mind elaborating on these two points please?
If I read you correctly (which I’m not sure I have tbh), only linear phase loudspeakers are acceptable in your view? Is that correct?
I would emphasise that it is natural in order to highlight the absurdity of trying to correct something that isn't necessarily broken.I'm not sure why the emphasis on "naturally"
