WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Yeah for the cost it looks quite consumery inside. Not that there is anything wrong with that, but tacking on an extra $400 just for the name is... Its just a conventional amplifier in a 2U rack mount style enclosure.
Parasound, an interesting brand. Started off as sort of a low end brand then moved into the low to middle end audiophile category is the 90’s. We had a very early model at my fraternity in the mid 80’s, we abused the hell out of it, cheap and very loud.
Looks like it does to me. The usual industry/advertising convention, although not stated in those specs, is for manufacturers to quote maximum power at <=1% distortion, which is -40dB.
Amir's much more conservative convention on those plots is to mark the elbow where the distortion starts to climb. (Some have suggested this penalises amps with better distortion - at say 200W, an amp Amir rated at 190W might do better than an amp Amir rated at 240W - the 190W amp's distortion is rising, but could still be better than the 240W amp...)
So you want to be reading off where the trace crosses the -40dB gridline. Very close to the specced 225W for 4 ohm, and comfortably above 150W for 8 ohm. I'd say it met its specification.
With amps that have a more gradual distortion profile I would definitely agree. At least for me amps that have a fairly steep knee where the distortion takes off his measurements are reasonable since there's usually not much more juice to squeeze beyond that point under steady conditions. Although one thing it has in its favor is the unregulated supply which can cope with brief transients better. With switching stuff even the most impulsive music changes at a glacial pace compared to the speed the electronics usually run at (edit: Not to mention they are also regulated), so no joy there. But given how powerful some of the class D amps are, it doesn't matter unless you really intend to run the thing flat-out.
I have what I think is an older version of this amp, the HCA-1000. Well maybe not specifically an older version of the amp, possibly an ancestor in some way. It's a John Curl design, for what that's worth- he's, well, let's say he's "colorful."
I bought it used for $200.00 six years ago. For that money, it's a pretty good amp. I use it to drive woofers in bi-amp or tri-amp projects I am fooling around with. It seems really reliable. I've never used it to drive "full range" speakers, just for the low end in systems with MiniDSP crossovers.
Though I am scratching my head. Parasound lists 2x225W @ 4ohm. My past experience with Parasound was listing RMS power per channel. Based on the results…might be a little bit of marketing here.
By domestic audiophool standards, it's still worthy!
All you SINAD chasing youngsters will obviously feel different though, such is the sluggish rate of progress in mainstream domestic mid to high end audio. Parasound never really made huge inroads over here I recall and if they did, I suspect it was home theatre and custom install - fit, set the gains on the back and forget with the unit hidden in a cupboard...
Only three things changed…amp swap + use XLR now (versus RCA) and rerun Anthem Room Correction. So rewatching the same scenes at the same volume dialog and environmental sounds are much more noticeable and clear. Maybe it is placebo. But I really prefer the sound of the Hypex amps over this traditional A/B unit. Lacking these objective measurements…that’s what we are down to opinions and perception.
But you play a piece of music on a cheap boom box…then play the same piece on a $25,000 2 channel set up. Probably can hear more clarity and depth right? To my ears I hear more depth and clarity in the class D. Best I can tell ya.
I had this amp and an outlaw 5000 (very similar performance numbers) at the same time and swapped them between the same electronics and speakers and this parasound 2125v2 always sounded blah to me even though I wanted to keep the parasound and sell the outlaw. The high pass filter on the parasound, when you turn it on, is like putting your hands over your ears.
The design on these dates back to the early 90s with only minor changes. A fair value then, not so good now. An opportunity for those who want a vintage amp with a new warranty.
The performance here seems to cheapen the THX Certification Badging. I thought THX had high performance standards as that is a large amount of distortion permitted. Curious results from a company with fairly high reputation. Thanks Amir and @Highmodulus for sending in the unit.
On edit: interestly this Amp does not show up on the certified Amp/AV separates list. Only 5 Parasound Amps appear Certified by THX at any level.
IMO, it meets their spec (click the "Specs" tab on the product page for the actual specifications.) They specify THD "at full rated output" to be 0.25%, which by my eyeballing of the measurements, it meets at rated power. They do skirt the FTC rule by specifying two THD ratings, but at least it's clear.
It beats its specifications in terms of distortion and is subjectively transparent, but the performance is more in line with older class B designs from the 80’s. If its the kind of design that is durable and puts up with abuse, I could potentially see it being useful, but at close to $1k and only having moderate amounts of power, it’s not the best value.
I bought one on sale for $599 probably a year ago, and it is a noticeable improvement over the amp section of my Denon x4400h AVR--more headroom and clarity. And I am not playing it that loud with my B&W 704 speakers. So for $599, I'm happy with it.
I bought one earlier this year for $599 (open box) and I too am happy with it. I wasn't thrilled with the reduced gain when the high pass filter was engaged, but I don't have a need for it either.
