Perlisten S4s for Home Theater
Descartes
I have a small room 12 x 11 x 10 and want to have on wall speakers as I can’t install in walls speakers.
I saw that Perlisten has an on wall speaker S4s for surround sound, would this work as well for the front LCR?
Ghost2231
Sure but at $4k a piece you could do much better. Do you like these because they are angled down and you want to mount them up high?
D
Descartes
Not necessarily I just need to find good on wall speakers!
D
Descartes
Ascendo passive 6
Totem tribe III
DALI Opticon
Ascend acoustic duo v2 LCR
None of these are likely to disappoint you.
Looking for a concentric driver ! I guess the Ascendo would work if they were not so ugly
FrantzM
Hi
A bit out of left field. You were considering Perlisten, at $4k. Wouldn’t Genelec 8341, mounted in the wall/soffit be a serious consideration?
Peace.
D
Descartes
Hi
Peace.
Yes except I heard one can get better pricing with Perlisten
